Oil Consumption?
Old Oct 31, 2006 | 03:11 PM
BlkTn2k4's Avatar
Oil Consumption?
I just had my oil changed 1500 miles ago. Checked the crazy dipstick and it's about 1/3 down in the acceptable range. Does anyone consider that normal? My car is an 04 coupe with just under 30k. I put in 5 Qts Mobil 1 Supersyn 5w30 and used a K&N oil filter. I'm just wondering if I need to be concerned about this. By the way, does anyobody know how much oil it takes to move between the H and L marks on the dipstick? Any insight would be appreciated. I talked to a service rep at Troncalli Infiniti and he said it's normal for the level to dip at this point.
Old Oct 31, 2006 | 03:26 PM
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/search....archid=1781169
Old Oct 31, 2006 | 04:20 PM
g35rcr's Avatar
its going to burn some oil, no way around it
Old Oct 31, 2006 | 04:39 PM
BlkTn2k4's Avatar
So you're saying that's somewhat normal? I just want to make sure it's not something I need to be overly concerned about. Thanks.
Old Oct 31, 2006 | 06:47 PM
Curt G's Avatar
It's absolutely normal. The top to the bottom of the "normal" range is 1 quart. So, you're saying you drove 1500 miles and used 1/3 of a quart. That's fine.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
