MAF cleaning major success story
Old Nov 11, 2006 | 07:17 PM
JZ39's Avatar
I've had either a K&N panel filter or JWT on my car for about 35,000 miles.
About 7 months ago, I noticed what appeared to be a "miss" at idle where the engine would shudder for a moment and then recover. At the time I noticed this, I had my Stillen dual catback on, Motordyne spacer and K&N panel filter.
This drove me crazy for awhile and I was getting ready to start systematically eliminating possibilities starting with new gaskets for the spacer, then resetting the throttle body and air sensors, then new plugs and finally back to stock if I had to.
So, today I got up and went to two Pepboys before I found a can of CRC MAF cleaner. I spent the 5 mintues it takes to remove the MAF sensor and clean it and then I took the car for a drive.
Long story short, the car idles better now than when it was new! The shudder is gone and the car revs so much smoother now words cannot do it justice! I've actually taken a couple of drives today just to feel how smooth and responsive and quiet the car has become. It's like night and day!
I cannot stress enough that everyone should spend the 6 bucks to clean their MAF, expecially those with intakes that can get oil on the MAF. I guarantee it will be money well spent!
CRC also has lots of other cleaners, throttle body etc. that probably wouldn't be a bad idea either.
Old Nov 11, 2006 | 07:28 PM
Calvin's Avatar
Overglorified Altima
it seems like everyone who cleans their MAF is having great success. ill keep this in mind when my car has more miles on it. thanks for the review.
Old Nov 11, 2006 | 07:41 PM
Nismo G's Avatar
I just cleaned mine as well maybe 4 days ago and its so much better. Throttle responce is better as well!
Old Nov 11, 2006 | 10:14 PM
D87's Avatar
D87
Hey JZ39, can I trouble you to do a write-up on this? I thought I read in other threads not to take out the sensor to clean it as opposed to what you did. Yes, I'm confused... but glad this worked for you!
Old Nov 12, 2006 | 12:05 AM
TURBOTOM's Avatar
a.k.a kleicoupe
hmm my car has like 25k miles on it, and i have had the stock intake, the pop-charger, and now the stillen. Would it be worth it to clean the MAF?
Old Nov 12, 2006 | 12:04 PM
Chrlesmd's Avatar
I just cleaned mine this morning. I did notice smoother idle and a little better response. CRC recommends cleaning the MAF everytime you change your air filter. Certainly can't hurt.
Old Nov 12, 2006 | 08:01 PM
JZ39's Avatar
The procedure is very simple.
With the car off (no need to disconnect battery), pull the plug off of the MAF sensor that is just behind the stock aribox. You have to press down on the tab on the top of the plug and then it pulls right off.
Unscrew the MAF sensor by undoing two screws holding it in. On my Z these were phillips screws; on my G they were Torx 20 safety screws.
Pull the sensor out and then spray 10-15 times on the exposed elements and then let it dry for a few minutes. Put it back in, put the screws back in, re-plug the harness and you are done.
Don't touch or otherwise molest the elements!
I still can't believe how much smoother my car is running.
Old Nov 12, 2006 | 08:18 PM
D87's Avatar
D87
Thanks! I'll go shopping this week for the CRC!
Old Nov 12, 2006 | 08:28 PM
MIC's Avatar
MIC
Is the MAF the same as a K&N filter. Can you just swap the MAF for a K&N?? I haven't had to replace this yet.
Old Nov 12, 2006 | 08:35 PM
JZ39's Avatar
Here's a thread with pics...
http://www.my350z.com/forum/showthre...&highlight=MAF
Old Nov 12, 2006 | 09:26 PM
LT1 SS's Avatar
The MAF is the mass air flow sensor, not a filter.
Old Nov 12, 2006 | 11:23 PM
blksnake's Avatar
CRC MAF Cleaning instructions here
Originally Posted by derek173
Old Nov 12, 2006 | 11:45 PM
bull3t's Avatar
so where do you spray it? in the hole on the side? or just the whole thing?
Old Nov 13, 2006 | 12:40 AM
blksnake's Avatar
bull3t, read this:
https://g35driver.com/forums/showpos...77&postcount=7
Old Nov 13, 2006 | 12:45 AM
bull3t's Avatar
okay i did it...im gonna wait til tomorrow to start it up...my engine would shudder sometimes just like the OP...hope this solves the problem
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
