need some infos (help)
Old Nov 20, 2006 | 01:03 AM
rjcs03's Avatar
guys, im gona buy a new g35 coupe second hand, and there are a lot of complaints bout the tranny and brakes i think... what are the things i need to check? and can you please tell me what are the reasons why i need to buy this car instead of subaru wrx sti and evo mr... thanks guys...
Old Nov 20, 2006 | 01:06 AM
nchima's Avatar
If your asking why you should buy it over an STi, then pick an evo or STi.
IMO, g35 more refined, somewhat decent power and STi and Evo don't come close to the look of the G.
my .02
Old Nov 20, 2006 | 01:39 AM
xx7sephiroth7xx's Avatar
G
evo & STI = fast
g35 = not as fast, luxury
imo, of course. :P
Old Nov 20, 2006 | 05:06 AM
StealthShinobi's Avatar
My Life be like Oooo ahhh
the only thing the sti and evo beat a G on is speed. The G is much classier and sexier.
Old Nov 20, 2006 | 05:45 AM
Og_Dave's Avatar
im old hah i picked luxury and sporty than just plain going fast and speed
Old Nov 20, 2006 | 11:33 AM
rjcs03's Avatar
ah i c... what are the things i need to check in a g35?
Old Nov 20, 2006 | 11:49 AM
TheKnite's Avatar
When buying, the most important thing you should worry about is that the dealer will honor the remainder of the car's warranty. Next, test drive the car, and make sure you have no problems shifting thru any gear. Notchiness is common, but grinding is not. Other than that, are the usual things, that the car don't vibrate on high speeds, the brakes work and don't vibrate, that the car had not been in an accident, painted, abused, used too much, etc. Good luck.
Old Nov 20, 2006 | 11:52 AM
STEVE-O's Avatar
My girlfriend and I went to breakfast Sunday. We noticed a very attractive couple in their 30’s leaving the restaurant at the same time. He put on a Breitling hat and we bet on what car he had in the parking lot. He got into a (very nice) sti. She said “He’s got a Subaru”…I said “a very fast Subaru”…She said “It looks like ****”…
Enough said.
Oh, get a CARFAX. That’s about all you can do. They are pretty good cars. I lost my 6MT transmission with no warning. They replaced it under warranty and that was the end of it. Just get the car and enjoy it. If you want absolute piece of mind get a Honda. And I will pass you and wave. Unless its an S2K.
Old Nov 20, 2006 | 12:38 PM
sfinaki2000's Avatar
Exclamation
Bought a used G35 myself. Things to look at:
Accident: Check to see if it's been in an accident. Look at the hood. Does it align correctly in front and on the sides? Look at EVERY body panel to see if everything lines up. Also, look at gaps between panels and hinges, are they properly spaced? Open the doors, do they open correctly? Once open, rock them up and down, they should be solid. Also, look in the cracks for uneven or differently colored paint or overspray. Open the door and look at the hinges, open the hood and look at the lip of the hood. Also, if you can have someone drive behind you during the test drive to look at the car while it's on the road, that'd be helpful to check that the frame is straight while driving.
Wheels & Tires: Look at the tires.. are they original? Do they have tread? Are they all the same brand? Are the back ones 245mm and front 225? Back tires should be bigger. Look at the rims, are they scratched?
Interior: How's the interior? Leather cracked? Dash cracked? Loose panels? Go over everything with a fine-toothed comb.
Engine: Don't be fooled by a clean engine. It's easy to get a detailer to clean your engine. Do a visual inspection. Look at EVERY part. When you drive it, listen closely. Tell the salesperson to shut up while you drive. Turn off the radio. Listen to ANYTHING that might not sound right. Be overly cautious. How does it shift?
Lighting: Check all the lights, they are expensive in our cars. For the headlights, pop open the hood and look at the headlights. Our headlights are really weak when it comes to accidents. Look at the bolts that hold the headlight in place... any cracks where the bolt holds down the light? Check high beams, low beams, fog lights, reverse lights, brake lights.
Keys: Do you have all the keys? You should. Get multiple keys and multiple keyless remote fobs, or you'll spend hundreds on new keys/transmitters.
MODS: Stay away from modded G35s. IMHO, a modded G usually means a G that's been driven pretty hard. You'd be hard pressed to find a G that hasn't been driven hard, since it's fun to drive that way, but from my experience, a modded G is a G that's been redlined more than once.
VIN Number: Get the VIN number, and if you have time (and you SHOULD have time, remember, dont' rush) call up an Infiniti dealer and talk to a service rep. Have em look up the VIN number. Tell them you're buying an Infiniti and wanted to make sure the car has been serviced regularly. Even if they can't tell you any details, they'll most likely tell you if they see something odd.
Lastly, TAKE YOUR TIME!!! Do not rush inspection of your car. People get an adrenaline rush buying a new G and MANY times, overlook a lot of obvious points. Carfax doesn't tell the whole truth, especially is someone got into an accident and repaired it at some random garage without ever reporting it. If you can, get a certified pre-owned or get it from a dealership. MUCH less risky than buying from a private party.
I bought mine and i'm completely happy with it. If you get a good one, it'll last you a very long time. FYI, I bought mine 3 months ago: 2004 G35 Coupe, 18's", Twilight Blue, 19,500 miles, 27K out the door, taxes included. Had some scratches on it, but got em buffed. Runs like a charm.
GOOD LUCK!!!!!
Old Nov 20, 2006 | 12:41 PM
stryder529's Avatar
GOOD LUCK!!!!!
good advice and the most important thing is if you really want the g35 coupe, simply ignore any creaks and rattles. just kidding it's not the most solid interior but our interiors are not as perfect as your expectations might be of a luxury car
Old Nov 20, 2006 | 04:28 PM
rjcs03's Avatar
really really really thanks for the inputs...
yeah i aint rushin, and eventho i really wana take home the car, i pretend that i aint interested... hehehe so taht i can bargain the price, i test drive i think 4 g35s, they all pull really good... and the last one is really my type... i drove the car fast, and breaks to hear or feel any imperfections, luckily none... ima do the rest when i get back there before thanks giving...
Old Nov 20, 2006 | 04:36 PM
kevinn's Avatar
Yes, up the STi and the Evo 9 because I didnt want a blow off valve going off every shift. Those cars are toys. I got a G for luxury, class [not the classiest, but some!], and style.
Plus, the women where I live don't go for rice rockets :]
Old Nov 21, 2006 | 02:21 PM
rjcs03's Avatar
yeah... almost all girls said that g looks better than those winged-car...
Old Nov 21, 2006 | 07:05 PM
mongsi77's Avatar
Buy mine!! PM me if your interested
Old Nov 26, 2006 | 09:35 PM
rjcs03's Avatar
wats ur price sir?
