Tiptronic bad for transmission?
Nov 24, 2006 | 03:07 AM
Hi I was wondering if you guys ever switch it from the tiptronic/manual shift mode to the normal AT mode when it's inbetween gears. Like when I accelerate to 4th speed, I then switch it to the normal AT mode...how bad is this to my car? any comments appreciated
Reply 0
Nov 24, 2006 | 09:48 AM
its not bad at all. the car is designed to switch modes at any given time, obviously you wouldnt want to drive around redlining in tiptronic but anything else with an auto is basically foolproof.
Reply 0
Nov 24, 2006 | 10:48 AM
Reply 0
Nov 24, 2006 | 11:30 AM
there have been one to many of these threads, but no it is not bad on the transmission.
Reply 0
Nov 24, 2006 | 12:27 PM
Quote: there have been one to many of these threads, but no it is not bad on the transmission.
word. been discussed a few times...youll be fine
i think if it was really bad then nissan would have made some sort of locking feature so that you can switch over to tip while driving
but thats not the case so yeh
Reply 0
im not sure but i use tiptronic all the time..i hope it isn't bad.
Reply 0
Nov 24, 2006 | 12:34 PM
The only thing that is bad for at trany is when you switch it into reverse while you are going 90 mph. And even then it will not switch. So you are safe.
Reply 0
Nov 24, 2006 | 03:34 PM
It's great for holding in gear when going through twisties, etc. and 'playing racer' but you will never shift as cleanly as it will in auto mode.
Using it all the time will be probably be harder on your gas mileage than your transmission.
Reply 0
Nov 24, 2006 | 05:12 PM
Some1 once tried to convince me that it was bad for my tranny. i just told them that if it was bad, I would have blown a tranny already.
Reply 0
Nov 24, 2006 | 09:32 PM
ya im sure its fine..i dont think nissan would engineer something thats going to hurt it that easily..i switch back in forth alot and not problems or sounds so far...
Reply 0
Nov 24, 2006 | 10:09 PM
Its not bad bro... Just dont make it a habit If you wannt feel like your driving stick you shoulda went that route =-P! JUST KIDDING MAN! loolol
Reply 0
Nov 24, 2006 | 10:23 PM
Its covered under warranty..........why worry?
Reply 0
Nov 25, 2006 | 12:52 AM
wait its coverd over warranty really..well what ever i barely use the tip only when i need to get somewhere faster....
Reply 0
Nov 25, 2006 | 04:34 AM
i almost always use manumatic
Reply 0
Nov 25, 2006 | 08:26 AM
The only bad thing for me was I was in auto mode and pushed the **** up thinking i was in manual. Boy was I in for a surprise . Finally realized the car was in neutral.
Reply 0
