L to H is how many quarts of oil?
Old Nov 26, 2006 | 05:08 AM
mc2's Avatar
mc2
A quick question, how many quarts of oil is between L and H on the dipstick? I'm about 500 miles past the 3750 oil change interval now and the oil level is halfway between L and H. Should i just wait until i bring it in or should i bother filling it up?
Old Nov 26, 2006 | 05:56 AM
Msedanman's Avatar
O.F. Administrator
I'm guessing about 3/4 - 1 quart which is not critical at all. If you plan on doing the change soon, just leave it..
Driving with the level anywhere in the cross-hatch area is fine.
C.
Old Nov 26, 2006 | 08:22 AM
chinee's Avatar
C.
It's truly a guess... From other cars, and from the feedback here, I've always assumed L - H indicated a range of approx 1 quart. However I just changed my oil and only a little over 3 qts drained out, plus what may have been in the filter, so there was probably less than 3.5 qts in the engine. I read the dipstick before draining and it was right around the 1/4 mark.
I parked on a level surface, my garage, and let the car sit for 10 minutes before reading the dipstick... no smudges or drips. Right around the 1/4 mark so I thought I was maybe 3/4 of a quart, but in actuality it was closer to 1.5qts low. Could the thatched area really be reflecting a range of 2 quarts?
Old Nov 26, 2006 | 12:47 PM
V35 Skyline GT's Avatar
6MT Coupe
^^^Hummm...that seems kinda weird. Can't explain what happened in your case.
Mine at L mark always goes back to F when 1 qt added.
Old Nov 26, 2006 | 02:17 PM
Msedanman's Avatar
O.F. Administrator
Wow, that is strange. I've never come across a L to H of more than a quart.
Might be out there, I've just never seen it...
I'll have to check that out on mine next fill.
C.
Old Nov 26, 2006 | 02:40 PM
mc2's Avatar
mc2
Okay, well that's kind of what i figured that anywhere between the L and H mark should be "OK" to drive with.
From my experience usually that area is about 1 quart also, 2 quarts seems like an awful lot.
Old Nov 26, 2006 | 03:04 PM
mongsi77's Avatar
How many quarts does it require for a H level after draining the oil?
Old Nov 26, 2006 | 03:11 PM
gary c's Avatar
How many..................?
My G35 coupe takes five quarts when I change oil.
That includes the mini-filter......it's sooo small why
bother.......haha On our twisted dip stick from L
to H is one quart, although mine has never seen L.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
