Coupe Wing Wiring?
Nov 27, 2006 | 04:45 AM
I currently have a 06g35 without a rear spoiler. I am thinking of doing a trunk swap with another g35 with a wing currently on it. Does my car come pre wired for an upgrade wing if I choose to add it, or do I have to do the wiring manually? Any DIY links? thanks
Kenny
Reply 0
Nov 27, 2006 | 01:40 PM
Yea it comes pre wired.. when you remove the trunk with the wing and your wing.. you'll see where the wires are tracked from.
Once you remove the push pins.. it'll basically be a straight forward job. Good luck yo
Reply 0
Nov 27, 2006 | 02:23 PM
Yep- what Imandresing22 said
Reply 0
Nov 27, 2006 | 06:47 PM
i dont have a wing right now! I bought my 06 g35 without a wing on the trunk. I have someone that has a wing on his car and wants to trade trunks for mine because he wants a plain trunk, no holes! You guys have a pic or something where I can check if it is pre wired?
Reply 0
Nov 27, 2006 | 07:38 PM
Just disconnect the HMSL and run those wires to the LEDs in your spoiler. I assume you're not going to run the rear deck light anyways.
Reply 0
