1) Is it worth to have a shorter shifter?
2) Any recommendation on brand and place to buy?
3) Can it be a self-installation?
I feel a little bit hard when shifting between my gears. Is it suppose to be like that? Any way to make it a SMOOTH shift?
Thanks for any comments!
i heard short shifters are DEFINETLY worth it...
I heard R.E. is the best place to get one....
yes they are DIY
I dont think a short shifter will actually give u soother shifting but dont take my word on that... and what do u mean a bit hard when shifting..explain more.
yes they are DIY
^ +1. How come no one has the stillen short shifter. Ive always been curious about that. Is it the price?
The rouge engineering short shifter looks really good but it keeps the same stock shaft height. Id rather have it a bit shorter.
Originally Posted by White03G
1) Is it worth to have a shorter shifter?2) Any recommendation on brand and place to buy?
Every car Ive driven that had a short shifter required just a bit more effort in rowing thru gears. by no means is it a bad feeling though.
1) Does B&M is a good brand to go for?
2) Where is R.E.?
when moving between gears, i need a little force to move it; and there's a gap (stop) at neutral. It's not suppose to be hard isn't it? I drove stick before and it's smooth as hell even though that's an Accord w/ out the short shifter. Thanks alot!
2) Where is R.E.?
I've drive both the Acura and Honda manual transmissions and both are effortless...smooth nonetheless, that it almost didn't feel like I was driving stick. Our G's ask for a bit more attention when shifting, I don't mind it, it gives me reason to learn to make it smooth. It's just the way our G's are designed...I don't think it's bad, but it could always be better...
I've driven both B&M and I currently have the Rogue Engineering on my car. B&M is shorter.. has a more notchy and solid, mechanic feel. The Rogue is smoother, not as short, but a great height, and is solid as well. However, the Rogue is easier as far as guiding into gears. It is precision, and I like it better than the B&M. I love the feel of the B&M.. but it's a little harder to guide into gears... tight fit.
Rouge Engineering is really good. I just brought one for my car not to long ago and it is a pretty much DIY install. What year is your car? All you need is a a 10mm and 12mm socket and a wrench. It should take you about 20 minutes tops to install. Check out rogueengineering.com and you can purchase it there.
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
did they get back in stock they stopped making them for a little bit
Quote:
Do you have pix of it? just wondering how height it is compares to the stock.Originally Posted by Hi-Tech_G
Thanks!
I drive with a RE Short Shifter and this is quite possibly my favorite best bang for buck mod ive done to my car! Its one of the little things that make everyday driving and even racing a completely different game! Now add that with a shift **** from a mazda miata and you will have the sickest short throw on a G. Trust me on this one
Quote:
Thanks!
It's the same height as stock, but the throw is (i think 20%) shorter.Originally Posted by White03G
Do you have pix of it? just wondering how height it is compares to the stock.Thanks!
Their web site has the specs.
GreenGoblin
close
- Join DateOct 2006
I cant wait to get one of these but its not on there site so I guess I will call them tomorrow
Thanks to you, guys. I think I know what should i get by now. I'll call them and will try to order one soon.
