engine damper kit
Old Dec 12, 2006 | 10:45 PM
  #31
Dan_K's Avatar
Installed the Stillen Engine Damper. I could tell a immediate difference in shifts and feel, both at low and high rpm. Shifts were smoother and more crisp, less vibration through the pedals as well. Downside is, since the damper is now effectively transferring engine movement to the frame, small rattles are now more noticeable. Rattles under the dash as more pronounced at idle. Going to see if the dealership can get rid of those.
If you are going to install this by yourself, have patience...a lot of it. Getting the damper through the B bracket with the bolt is a PITA. A little advice: remove the 10mm bolt holding the coolant tank and move it out of the way, this will give you more room to put the bolt through the bracket and tighten it.
Old Dec 14, 2006 | 04:24 PM
  #32
bobshuai's Avatar
so is it worth it to get it what do you guys think?
Old Dec 14, 2006 | 05:17 PM
  #33
chobble19's Avatar
definately worth it! if you pop ur hood and look at ur motor while you give it gas and let go u will see that ur engine "shifts" back n forth abruptly which isnt cool
Old Dec 14, 2006 | 06:47 PM
  #34
bobshuai's Avatar
anyone has any diy pictures to show how to do the installation?
Old Dec 23, 2006 | 04:54 AM
  #35
Dan_K's Avatar
It's pretty self-explanatory with Stillen's directions.
jsimonk
Dec 22, 2023 03:49 PM
reavensf
Sep 17, 2015 11:30 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
