***help*** another spacer install question...
Old Dec 8, 2006 | 12:34 AM
cchaorule's Avatar
After putting on the copper TB on the plenum and after putting the two hoses back on the new copper peice....what do i do with the other two hose fittings that are connected to the plenum? Fill with silicon im assuming?
Old Dec 8, 2006 | 12:48 AM
cchaorule's Avatar
anyone??? i am in the middle of the install.. any help is appreciated.. thanks
Old Dec 8, 2006 | 12:50 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
i'd love to help, but i didnt get the copper iso thermal. Doesnt say anything in the instructions?!
-GP-
Old Dec 8, 2006 | 12:57 AM
cchaorule's Avatar
Nope...It states to put the two water hoses on the new copper peice...nothing after that. I'm thinking about sealing it up with some silicon...would that hold?
Old Dec 8, 2006 | 01:19 AM
cmthresher's Avatar
you dont need to put anything on the old fittings. They are not internally connected to anything. It just ran through to cool. You just leave them alone. I have the isothermal copper also.
http://www.cardomain.com/ride/2447408
you can check out my pics. I have one of my isothermal but you cannot see the old fittings. Dont worry. Just install the old hoses on the new isothermal and you are good.
If you dont believe me. Just go ahead and do it and once you start your car you will see that no fluids leak out..
You will love this mod. Pick-up and sound. a definate great mod.
Old Dec 8, 2006 | 03:53 AM
cchaorule's Avatar
okay.. so i installed my spacer.. bad news.. i took off the upper plenum, and then the lower plenum to put the gasket ring thingi.. so then i put back my lower plenum.. and screwd it back.. i had a FT/LB torque wrench.. and i was converting it from inches.. aparently it wasnt that accurate and i went a little too hard on the screw... and i snapped it.. so i had to take off the plenum.. and i found the screw stuck in there with abotu 1 cm sticking out.. so i cant get that screw out.. so i left it there.. and bolted the other 5 bolts it.. should i worry about this??
Old Dec 8, 2006 | 06:46 AM
g35rcr's Avatar
yes go get an extractor and retap it...dont be lazy
Old Dec 8, 2006 | 10:51 AM
cmthresher's Avatar
exactly this could cause an air leak in your plenum. Get an extractor and be careful not to get any shavings inside. cover the engine good.
jsimonk
Dec 22, 2023 03:49 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
