Where do I get throttle body sensors??
Old Dec 8, 2006 | 02:20 PM
ireloaded9's Avatar
Guys- it's been over a year since I've been on the message boards. Sorry if this has been posted. I searched and found plenty of info on throttle body sensors but does anyone know where I can buy the parts?? I need to have the part replaced by next week for emmissions and the dealer wants almost 1k for the parts and labor. I figured I can find it for less online and have my mechanic do it for me. thx in advance!!
Old Dec 8, 2006 | 03:14 PM
DocJohn's Avatar
I'm not sure what you mean by "throttle body sensors". Are you taking about the throttle position sensor (TPS)? I'm not sure the TPS is a separate part on the G35.
Anyway, a new throttle body will set you back about $440 from http://www.riversideinfiniti.com/
Here's a used one on e-bay for $200
http://cgi.ebay.com/ebaymotors/ws/eB...m=290022891369
Don't forget to buy a new throttle body gasket too.
This is pretty easy to intall. You just have to remember to do all the throttle position reset proceedures when you are done. I can send these to you if need them.
Old Dec 8, 2006 | 03:30 PM
DocJohn's Avatar
I just check the service manual for my '04 G35. It confirms what I already said in that the TPS is an intergral part of the throttle body (electric throttle control actuator as its called in the manual), so that means you have to replace the whole throttle body.
Old Dec 8, 2006 | 04:38 PM
NgoWay's Avatar
Doc... you are correct. My check engine light came on and it was a TPS error. The dealership ended up replacing the entire throttle body. There is one other sensor, but I'm not sure where it is.
Old Dec 9, 2006 | 08:20 AM
DocJohn's Avatar
Its proabably the pedal postion sensor attached to the gas pedal since this is a drive by wire throttle system.
Old Dec 9, 2006 | 09:17 AM
Montara's Avatar
Smile
Nissan/Infiniti has been covering so many of these under powertrain warranty (5/70) that they now have a FACTORY RE-MAN. PN 16119-8J103 is replaced with 1611K-8J10BRE.
LIST $140.!!! If your powertrain coverage is expired BUY THE RE-MAN.
Old Dec 9, 2006 | 05:30 PM
garry101's Avatar
hey... i just bought a new throttle body too...but i dont need it becuase the problem was something else...i have one it hasnt been opened yet. it comes with life time warranty....i bought it from pams auto.....let me know if u want it...i need to sell it
thx
garry
Old Dec 10, 2006 | 03:38 PM
ireloaded9's Avatar
Doc- please send me the reset procedures.
garry- how much for the throttle body?
Old Dec 11, 2006 | 01:10 AM
garry101's Avatar
sorry man i ended up needing to use the throttle body.....
Hey Doc can u also send me the reset procedures...thatll be great
thx
-garry
Old Dec 11, 2006 | 01:26 PM
DocJohn's Avatar
Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It's best to time this with a watch or clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Dec 11, 2006 | 03:08 PM
chobble19's Avatar
what r u all doing do ur throttle body!??
Old Dec 11, 2006 | 04:54 PM
garry101's Avatar
thx man!!!
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
sullivan72
Sep 22, 2015 11:39 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Chadwick Arnold
Sep 9, 2015 02:59 PM
