for those of you with 20" rims - help
im thinking into getting 20" rims, i dont want wheel rubbing problems but i dont want tires that fit ugly in these rims ( rim wider than tire ) Im planning 10.5" in the rears so the tire is going to be 295. In this combination in worry about tires rubbing the fenders cause by Offset problems. I dont like 19" rims because i think that for a few more bugs you get 20" and that size of wheels are really notice against 18" stock wheels, and its better with greedy sideskirts and Kuruma bumper for clearing the floor and also the gap between the tires and whole fenders. I have Tokico D-spec with 350z Teins S spring, I know i will have to change the springs to rise the car a little more, maybe 350z Tein H. Btw my ride is a G35 2003 6 MT. Any suggestions in correct wheel offset fot these combination, springs and height issues, photos and tires will be apreciated. Photos photos phots!!!!!! tkx.
wheel + offset
Here is what I got.
20X8.5 offset = 20
255/35/20
lower on coilover about close to 2"
do rubbed on fender a little on hard turn or bump
solution: raise it 1/4" or +25 offset or go with 245 tires
20X10 offset = 35
285/30/20
no rubbing but could use more lower offset due to there is some gap from tire to fender.
solution: wheel spacer = 20-25mm or get rim with 20 to 25mm offset. or go with a wider tire like 295-325 depend on your offset and rim width.
I could go much more lower like 3" but the front setup I have right now stop me from going any lower than 2"
Hope this help.
20X8.5 offset = 20
255/35/20
20X10 offset = 35
285/30/20
Hope this help.
i ordered 20"x 10 nd 20x 8.5 i havnt put them on yet but my car has tein stechs and according to everyone ive talked to they will be fine i know people with the same setup and no rubbin for them
I'm running 20x9/20x10 right now with 255/30/20 & 285/30/20 tires. Very very close, but no rubbing yet. I'm slammed on Z Hotchkis springs, so I might roll the rear fenders just to be safe.
Originally Posted by 05BLACK6MT
Here is what I got.
20X8.5 offset = 20
255/35/20
20X10 offset = 35
285/30/20
Hope this help.
20X8.5 offset = 20
255/35/20
20X10 offset = 35
285/30/20
Hope this help.
Did you have any photos of the your wheels, I try to post my photos but something happend that i can do it.
inexorable
17 Inch
Sep 24, 2015 10:43 AM
