Quote:
C'mon guys, I'm waiting for this answer also. White lithium, or regular axle grease?Originally Posted by KiDFuZioN
What kind of grease did you guys use to fill in the control socket?
According to the instruction manual, "Grease (most greases are fine such as lithium based)."
With that said, I'm installing mine right now and I'm using "Uniplex Premium Hi-Temp Grease" which is a lithium complex grease.
Evil Bastard
use spit. works for other things that need lube. *snicker snicker*
I didn't really think the rogue SS would eliminate this, but anyone get a reduction in side to side play? And by this, I mean, when you're in neutral, and in center, you can shake the shifter from side to side slightly. Commonly known as "sloppy shifter syndrome"? I might put the car back up on the jacks and start messing with the linkage to see if I can tighten things up anywhere.
oh, just use any sort of long-life, durable grease. It'll be fine.
