install short shifter help
Old Dec 14, 2006 | 05:44 PM
White03G's Avatar
what is the easiest way to remove the factory control socket out of the shifter? i've been trying for 30 min. and run out of idea how to pull it out; even the brute force. thanks for any help!
Old Dec 14, 2006 | 06:57 PM
s2k_g35's Avatar
i am about to buy one too. any help would be great.
Old Dec 14, 2006 | 07:15 PM
BayAreaRefuGz's Avatar
i fly low
search search search search search search search
https://g35driver.com/forums/showthr...t+installation
Old Dec 14, 2006 | 07:32 PM
clifftrail's Avatar
Are you talking about the white plastic bushing on the ball portion?
Old Dec 14, 2006 | 07:49 PM
Hi-TechG35's Avatar
You don't have to. I just put an RE in my car about a month or so ago. Just pull the trim up around the shifter and unscrew the first layer of bolts. There are 4 10mm nuts and then you take othe other three. Go under the car to unscrew the 12mm one that holds the shifter in place (use a small size ratchet becaus you have to get your hand above the exhaust pipe. and you are all set. PM me if you need some more help.
Old Dec 14, 2006 | 07:51 PM
Hi-TechG35's Avatar
If you are talking about the white plastic that clifftrail mentioned you don't remove that. When you buy your short shifter it automatically comes with it.
Old Dec 14, 2006 | 08:24 PM
KiDFuZioN's Avatar
No it doesn't. The Control Socket is an extra you have to purchase if you don't want to take off the old one. It's about $12 bucks for the socket. The part number is 32870-CD000.
Old Dec 15, 2006 | 12:13 AM
White03G's Avatar
geezz.. i should have known. Tried to take the control socket out of the stock shifter is such a pain in the ***; I still stuck with it. I guess I need to order one. Thanks!
Old Dec 15, 2006 | 12:21 AM
White03G's Avatar
Buy the control socket. installation is piece of cake. just pull out the installation guide from RE.
Old Dec 15, 2006 | 10:01 AM
Diesel1's Avatar
Moderator
You can reuse the old SHIFTER CUP. The shifter only comes out one way so make sure you look at it carefully first.
1. Use a vise or something else that has 2 sides and an open center (2 tables, etc). Place the cup onto the vise, not in it, so that the the side where the shifter will exit is resting ontop of the vise -I- (Best pic I can do) The I is the shifter, the - is the vise and the cup would be resting ontop of the vise.
2. Be sure that the shifter will exit down. Now grab a piece of wood, phone book, etc and place it ontop of the metal shifter (Top of the I). Grab a mallet and give it a good WHACK! The shifter will drop down!
3. Be sure to have something below the vise etc to catch the shifter!
4. Install old cup onto new shiftwer in the reverse manner
Old Dec 16, 2006 | 03:17 AM
White03G's Avatar
Thanks for the advise! I will try it later to see if it works. Either way, I already placed order for a new control socket at my local dealer for $17. Can't wait to feel the RE shifter.
Old Dec 18, 2006 | 12:09 PM
djricepik's Avatar
I installed a B&M Shifter on my car over a year ago, and there was nothing that I needed to reuse. Everything slid right onto the car...
Don't know what brand you are using, but sounds like a pain in the ***...
Old Dec 18, 2006 | 02:26 PM
madscientist's Avatar
when i put my rouge in i bought a new one. I remember reading somewhere that popping the old shifter out of the plastic thing put a lot of strain on it (and was a pita) and compromised its strength.
Old Dec 18, 2006 | 05:11 PM
KiDFuZioN's Avatar
What kind of grease did you guys use to fill in the control socket?
Old Dec 18, 2006 | 11:08 PM
GreenGoblin's Avatar
The goblin resurrection
I cant wait mine will be here tomorrow
