Light Bulbs Question
Old Nov 11, 2003 | 10:01 PM
Fiebru's Avatar
The owner's manual show H1 (55W) as the Low Beam and HB2 (60/55W) as High Beam/Fog Light. Forget my ignorance, but does that mean the same bulb is used for High Beam and Fog Light? I'm assuming that if I want to replace my Fog Lights, I have to buy a 60/55W bulb. Can it be replaced with an HID kind without any mods/kits, etc? Is the K, as in 8000K, irrelevant as long as you get the right power, 60/55W? Thanks!
Old Nov 12, 2003 | 12:29 PM
ryoken's Avatar
Re: Light Bulbs Question
Yes, the high beam and fog light use the same bulb. If you're going to a "same color" effect, then you want a regular (not HID) bulb with the higher color range (not sure if it's 8000K, though).
You can't put an HID bulb in the regular slot.. the HID bulb's don't run at 12V, and require some sort of power transformer to operate, which is why they have kits for them.
Old Nov 12, 2003 | 05:22 PM
Fiebru's Avatar
Our main headlights are HID, correct? So if I need a regular bulb for fog light, probably those Sylvania Silverstars should do the job, shouldn't they?
Old Nov 13, 2003 | 01:18 AM
Gordgee's Avatar
Administrator
Some of the early G35s sold in the US with H-1s as the main beam. I think HIDs are standard now. I like my SilverStars and find they're a good upgrade for the H-4s. Some have found that other brands worked better for them.
<font color=green>GG</font color=green>
wonderizm
Sep 24, 2015 03:09 AM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
attarday
Jul 15, 2015 04:03 PM
