Next mod time......could use a little help
I trying to decide on my next mod for my 04 coupe (6mt), currently I have a stillen intake, Crawford intake plenum, stillen exhaust, and UR pulleys.
Anyways I’m thinking about going down the UTEC, or UNICHIP road, however I’m not too sure what kind of gains too expect. Any comments from you guys that have installed this would be much appreciated.
Also, although my clutch is still going fairly strong I have also considered the clutch/lighten flywheel combo. Basically I would like to improve the acceleration i.e. 0-60 performance.
Any suggestions/comments?
Next mod...............?
Since you have the Crawford intake plem I suggest you call Tony and ask
his advice on adding the MREV. This would be the best bang for your $!
MotorDyne 661-993-5111 ask for Tony.....LOL
The Crawford is like the 1/2 spacer. As for the lightened flywheel, it's great in first gear but that's about it. The clutch???? If yours is going then do the both just add more clamping pressure if you intend to spray or FI your car. I had JWT fly and clutch and loved it. Unichip is not bad or a reflash of your ECU but I would get the Utec. As you play with your mods you can tweak as you go. Good for N/A , Spraying and FI. Can't go wrong really. The only downfall is the tunning of it. You can get the "tuner pro" and have all the toys to be able to tune yourself or you need to go get it done by a pro on their Dyno.
Thanks guys for all of the advice, this helps a lot.
I believe I am going to call Motordyne and see what they suggest, if I support the MREV2 product then that will definitely be the best bang for the buck. Perhaps after I get this installed I may go with the UTEC to maximize all of my mods. Also I have not installed headers yet because I was told that some people have had problems with O2 sensors and check engine lights coming on once installed. Anybody with headers that has any input, your comments our welcome.
Thanks again for the help.
