06 6MT Coupe with rev Up motor. What is fuel cut?
According to the tach the redline is 7k but looks like Nissan left some room so you wouldn't hit the limiter. Does anyone know what rpm the fuel Cut/Rev limiter is set at?
Originally Posted by Ralph0064
ive taken mine up to 7100 ish-7200 before it started bouncing off of rev limiter.
Are you sure? My tach must be off by alot then because some how mine revs to 7600 according to the tach.
This is coming from someone with the 03 non rev but.... I believe all the vq's redlines are equal (03/04 if you TS the ecu) at 7200 rpms. However, (again dont know this is true of rev ups) even with aftermarket cams and a few other goodies, my motor actually looses power after 7000 rpms. 7600 would be insane and I would forsee things breaking at this rpm, as the motor even feels as if its straining in the short 200 rpms above 7k I can go to.
Originally Posted by ON_6MT
7600 rpm
granted i have an 06 6mt sedan but its the exact same.
drifted a turn with a little to much right foot and the needle held 7600 like it was glued.
interesting that the 07 redlines at 7600 now
Ok so i am not crazy....I was getting onto the highway and i was in second accelerating when i turned to check my mirror as i heard a horn. when i looked back at my tach it was at 7600 so i shifted 3rd and it chirped the tires. I can't belive that nissan would leave a 600rpm window on the fuel cut.
