Problem with my lights
Old Dec 29, 2006 | 03:04 AM
Flavius's Avatar
ok so i tried to put different light bulbs so i put a light bulb which probably was high wattage into the socket for the side marker light in the bumper and i saw a spark and all of a sudden both sidemarker lights won't work anymore also the Clearence lights in the headlight... i checked the fuses but they all seem to still be good..anyone have any possible solutions to this delema...
Old Dec 29, 2006 | 06:37 AM
Maciuniu's Avatar
yea it might be your relay but not realy possible.Make sure u check the fuses GOOD they might look ok but they are not (btw there is 2 spots under the hood and in the car)
Old Dec 29, 2006 | 06:55 AM
g35rcr's Avatar
check the fuses and relays behind the battery...you might have fried your bulbs when you changed out the other ones as well
Old Dec 29, 2006 | 12:43 PM
Flavius's Avatar
how many Fuse boxes are there? i kno the one under the steering wheel on the left. and the one right in front of the battery under the plastic cover.... and if so does anyone know which fuse it might be...this affected my marker lights the clearence light i think in my rear as well...it sounds like a fuse most likely because the headlights work fine and turnsignals ect....thanx guy/gals
Old Dec 29, 2006 | 04:01 PM
a13xkim's Avatar
there is a third fuse box behind the battery. You have to take off the entire cover and reach behind the battery and you will see a black plastic box which u can pull off because its just a cover. inside that fuse box is a fuse for the tail lights which could be it since u said your tails dont work. But if not that there are lots of other fuses in there.
so there are a total of 3 fuse boxes.
Old Dec 30, 2006 | 02:03 AM
Flavius's Avatar
ok Success ....the burned fuse was in the 3rd box...thanx to G35 driver i found it no thanx to the owners manual......thanks for the help
Old Dec 30, 2006 | 09:42 PM
a13xkim's Avatar
good job
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
