6MT 04' Idle problem after installing after market units!!!
Old Jan 7, 2007 | 07:49 PM
.:Brown Man:. J's Avatar
also after installing the tvandnav2go unit and unplugging the battery before working on the installation when you plug it back in and start the car, do you guys have idle problems with the car when it starts, there is something wrong with my Code 1P0165 ECM Power Supply when my buddy at the shop test the problem, seems to be an idle problem when the car starts it would shut off right away, tried it repeatedly and then it would shut off like it won't start unless i give it a little rev. to it then it starts up, 6MT Coupe 04'
NEEDD HELP!!!!!!!!!!!
any others with the same problem?
heard that i need to drive the car for a bit since the battery was disconnected the computer chip could have reseted and needs to drive and re-cycle its work to make the car run smooth as normal again??
Old Jan 8, 2007 | 05:49 PM
please really need help with this, any others have the same problem??
chinee
Jun 10, 2024 07:48 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
tiguy99
Mar 1, 2016 11:42 AM
Phenomenon9
Aug 9, 2015 01:34 AM
brian_z
Jul 22, 2015 09:19 PM
