steering wheel vibrates
Old Jan 16, 2007 | 12:12 PM
jersey-G's Avatar
Originally Posted by Heikes
According to the movie My Cousin Vinny "you got mud in your tires"
How do you get mud into the tire?
Old Jan 16, 2007 | 12:36 PM
oOmikeyboy's Avatar
Florida G35 Club, Premier Member
This one time after sliding around a little bit i had mud attached to the inside of the rim, which acted like wheel weights and threw off the balance. i just hosed it down and voila, all fixed.
Old Jan 16, 2007 | 01:14 PM
akavietboi77's Avatar
Mine Steering wheel was vibrates at high speed and i bring mine in to the Infiniti Dealer and they turn my rotor and change my brake pad under warranty.. I did not pay 1 penny and it fix my vibration in the steering wheel plus I did a alignment and balance to and that didn't fix my problem but the rotor turning and new pad fix everything!!!
Old Jan 17, 2007 | 08:17 PM
636Racer's Avatar
if it's a TSB, warranty will kick in.
Old Jan 17, 2007 | 08:28 PM
bocatrip's Avatar
Sounds like the typical balance issue with early G35 Coupes. I need to balance mine every 3,000 miles due to feathering from the "front end issues" due to lack of camber adjustment. If you have directional tires as I do, you need to break each tire off the rim, flip them, and swap them from side to side. It's a pain, but it's the only method to increase the life of your tires without having to get an expensive camber kit. Good luck.
Old Jan 17, 2007 | 09:05 PM
kennyz424's Avatar
most likely a wheel allighnment man...happens to me at 80+ mph
jsimonk
Dec 22, 2023 03:49 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
