cable through fire wall
Old Jan 26, 2003 | 10:06 PM
m1dtom's Avatar
has any one run a cable through there fire wall yet.
i just ordered a remote radar detector and will need to run antena wire through it.
just wondering if some one ran a power wire for amp or auto start or whatever. if so could you please post location and difficulty.
i havent yet looked on my car as i just ordered a whistler 3300 remote about an hour ago.
any help would be great
tom
Old Jan 27, 2003 | 06:43 PM
gbest03's Avatar
Re: cable through fire wall
I have the same unit.
I drilled a hole thru the fire wall, just up and to the left of the brake pedal. (looking at it from the inside)
Be sure to seal the hole with silicone, as the water runoff from the windshield seems to splash onto the windshield wiper motor, and then runs down right where I drilled.
I chose this location because the remote starter installer used it, and it seems to be the only good place to drill.
I mounted the Whistler display unit right in front of the cig lighter.
I took the guts out of the socket, and ran the wires through it.
Picked up power from the lighter plug.
You can see the display through the steering wheel, I did this on my sedan, and will transfer it to my coupe once it arrives.
And where you sit lower in the coupe, I think it will be easier to see.
BS Sedan for now, DG Coupe end of March
Thebaws11
Jul 2, 2021 11:36 AM
yosip1115
16
Sep 28, 2015 04:14 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
