Installing new clutch and flywheel, But should i do a throw out bearing ?
Old Jan 19, 2007 | 03:12 AM
jadenharrow's Avatar
I am installing the jwt clutch and fly combo, and my friend the other day said i should also make sure to do my throw out bearing, Should i do this ?
I dont know much about cars but i have been trying to leanr over the last 6 months, any info would be nice
thanks
Old Jan 19, 2007 | 03:43 AM
cloud's Avatar
yes you should
Old Jan 19, 2007 | 07:03 AM
g35rcr's Avatar
well considering most clutches come with their specific throw out bearing it would be foolish not to use the new one
Old Jan 19, 2007 | 07:42 AM
GR8TG35's Avatar
thanks
The throw out bearing is the weakest link in a clutch assembly. They usually dry out, which in turn gives you that spinning/whinning sound when you disengage the clutch.....
If you plan on replacing any component in the bell housing, its best you always replace the throw out bearing....its an inexpensive part, and you should invest in a good brand name/quality bearing assembly...
just my $.02
Good luck
Old Jan 19, 2007 | 11:46 AM
GEVO's Avatar
Yes
I dont know much about cars but i have been trying to leanr over the last 6 months, any info would be nice thanks
Do the bearing while you have it apart, or you'll end up replacing it later on!
Don't sit at a traffic light with the clutch disengaged (your foot on the pedal ) and the car in gear. This will help the life of the release bearing immensely.
Depending on the mileage of the car, I might take the flywheel off and replace the rear main seal too and maybe even the input shaft seal on the transmission.
Good luck!
GEVO
Old Jan 19, 2007 | 11:57 AM
GreenGoblin's Avatar
The goblin resurrection
It wuld be foolish not to replace it while it is all apart
Old Jan 19, 2007 | 12:14 PM
does an anyone know of a website i can order a throwout bearing ?
Old Jan 19, 2007 | 12:22 PM
g35rcr's Avatar
a new jwt clutch kit comes with a throwout bearing
Old Jan 19, 2007 | 12:24 PM
ORANGEBSRT's Avatar
yup. replace it.
Old Jan 19, 2007 | 12:40 PM
Mike_Deezy's Avatar
you should replace it, might as well get two birds with one stone.
Old Jan 19, 2007 | 01:12 PM
well I bought my JWT from Intense Mototrsports and they said throwout bearings don't always come with the clutch fly combo, and intense doesn't sell after market ones,
so does anyone know where I can buy an aftermarket throwout bearing via the web ???
Old Jan 19, 2007 | 01:16 PM
Jeff92se's Avatar
Red Card Crew
Replace it! Because you don't want to pay $300-$400 worth of labor AGAIN to get a $50 part replaced.
Old Jan 19, 2007 | 01:21 PM
OKay I am replacing but
Old Jan 19, 2007 | 02:05 PM
/bump for answers ^^
Old Jan 19, 2007 | 03:30 PM
g35rcr's Avatar
jim wolf but it should ALWAYS come with one, their kits ALWAYS come with one...call jim wolf
