Washer Fluid Indicator
Old Jan 19, 2007 | 12:00 PM
beaux1977's Avatar
Unhappy Washer Fluid Indicator
Hey all,
I have an '06 IP. Quick question about the washer fluid indicator . . . When I take sharp left turns or long left turns pulling hard I notice my washer fluid indicator kicks on temporarily and shuts off. I checked the fluid level and it's fine. Has anyone else experienced this? Is this a design error in the sensor or could this be a malfunction?
Thanks,
Ad
Old Jan 19, 2007 | 12:26 PM
StreetChase's Avatar
i have an 06' and ive never had that problem lol...like you said its either because the fluid is getting moved away from the sensor when you turn or its malfuntioning. call the dealership and see what they say. good luck
Old Jan 19, 2007 | 01:35 PM
chobble19's Avatar
fill it up!
Old Jan 19, 2007 | 02:42 PM
SilverII's Avatar
it's simple.... you are low on fluid.
I bet if you fill it up right now, you can put in 1 gallon of fluid!
Old Jan 19, 2007 | 03:07 PM
ouki's Avatar
I have a new 06 G35 coupe, it does the exactly the same thing. I also drive a 05 sedan and it did the same thing. It is normal. I don't think you need to worry about that but you do need to check your fluid and make sure it is not below certain level.
Old Jan 19, 2007 | 04:45 PM
kidtronix's Avatar
Optional
FUNNY, you guys where its warm run out of washer fluid. Up here we keep an extra container in the trunk! We refill constantly!
Wait, I have an 05. Do I have a low wiper fluid indicator too?!?!
Old Jan 19, 2007 | 10:20 PM
jdmeg21's Avatar
just top the fluid off. that should fix it till you use it up again.
Old Jan 19, 2007 | 11:28 PM
castertroy101's Avatar
exactly. Mine is currently doing the same. Fill it up and you should be good. Which reminds me I need to by some fluid too.
Old Feb 18, 2007 | 08:45 PM
Lucino's Avatar
who's the girl in your avatar and sig? she's too hot
Old Feb 18, 2007 | 09:12 PM
BadBoy06's Avatar
never seen this problem
Old Feb 18, 2007 | 09:14 PM
Maximus's Avatar
Ive seen it from time to time in my 04 coupe. Jus keep it topped off to avoid the annoyance
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
vamarris
Sep 26, 2015 12:56 PM
