Using Tire Chains w/ 19" Wheels?
Old Jan 19, 2007 | 04:40 PM
yamanb's Avatar
I second taking the bus. During the 4 days of snow/icy roads I took the bus and it was fine. A $3-4 bus fare is cheaper than a new set of rims or damaging your car from driving it in the snow when obviously our cars are not made to handle those conditions.
Old Jan 19, 2007 | 05:18 PM
MSUcougar's Avatar
Originally Posted by xx7sephiroth7xx
0_0 DO NOT put cables on your 19's. I'm pretty sure it will mess up the low profile tires. Also, the tires that Infiniti uses with these 19's are summer performance tires. This basically means that they have a tolerance for high temperatures but when it's cold out, the rubber becomes harder and you lose LOTS of traction. Just get the dedicated snow tires + rims for those parts of the year when snow would be a problem. It's a lot safer to spend $$$ on dedicated snow tires & rims than on repairing damage to your G after a bad accident from no traction.
Also, I'm pretty sure they do not have tires with studs anymore because they totally ruin the roads. :P
Buttt.... do what you want. This is jmo. :P
I've already experienced the summer tires in snow... as described, I basically lost traction at first glimpse of snow/slush/ice. It took me 3 tries to get up the small hill to my house with like an inch of slush on the road. It was pathetic.
They do still make studded tires... In Washington you can't install them until Nov 1 and must be off by April 1 iirc.
And yes I already use public transportation or friends when travelling around town in the snow... my main reason for making this thread was for required travel (mountain passes, visiting my parents in eastern WA, etc).
Old Feb 26, 2007 | 05:56 PM
94gxe's Avatar
Studded tires are legal in Washington during the winter. They chew the roads up very badly.
Old Feb 26, 2007 | 07:09 PM
FenixL1P's Avatar
chains and belts have potential of damaging your fenders and suspension arm too....
Old Feb 26, 2007 | 07:32 PM
icab's Avatar
Cougar,
I had the same dilemma as you (though I'm not in Washington). If you're saying you get that little snow, getting a set of dedicated tires is overkill.
a) If money is not an issue at all to you or you're an enthusiast and have to have maximum tire performance, then get a set of dedicated wheels for winter and for summer.
b) If you get a lot of snow where you live, get a set of snow tires and have them swapped every season. If you have a little extra money, get tires and dedicated rims.
c) If the G is more of "just a nice car" to you, then just get a set of all-season tires when the summer tires you have on wear off.
From your very own post, it sounds like you don't want to spend a lot of money on this issue, so it seems like c) is what you should do.
Old Feb 26, 2007 | 07:37 PM
icab's Avatar
I forgot to mention: I don't get enough snow here to justify dedicated wheels, but we do have snow storms. I tried just using summer tires like you and it's just sad to try to drive with summer tires. It "can" be done, but I would get stuck *everywhere.* Literally. I'd get stuck at a stop sign because there would be 1-3 inches of *soft* snow on the ground. I'd get stuck at the tiniest hills and IL is pretty friggin' flat. I'd get stuck at the company parking lot. I'd get stuck on my own flat driveway even after I cleaned it. So, yes, everywhere. If you have any little bit of snow *and* you have to drive the G, then summer tires are a no no.
Old Feb 26, 2007 | 07:38 PM
Hi-TechG35's Avatar
It's not a 4x4 it's a G. All in a nutshell I wouldn't chance it.
Old Feb 26, 2007 | 07:39 PM
BadBoy06's Avatar
Originally Posted by wilksoner
ur insane i would never put chains on my g take the bus when it snows
lmao...that would be a site to see
Old Feb 26, 2007 | 07:43 PM
savefatkids's Avatar
im sooo glad it dosent snow here lol
Old Feb 26, 2007 | 07:46 PM
icab's Avatar
Oh yeah, you could sell your summer tires pretty soon too and get the all-season tires. Now that summer is coming up, you should be able to sell them for a good price. :P
Old Feb 26, 2007 | 07:59 PM
avs007's Avatar
Chains and Low-profile tires can do more than just damage your wheels/tires... Usually they prohibit chains, becuase the clearance between the tires and the suspension components.
I know on my other car, I can barely squeeze my finger between the edge of the tire and the bottom of the strut assembly.
As far as summer tires/etc... Seattle weather is similar to Portland weather... You should not be driving around on summer tires year round... PacNW weather is not warm/dry enough in the fall/spring. All it takes is 40-50 degree weather with morning dew, light mist, or rain, and the stock summer tires will be like rolling ice cubes. Been there done that. (Tire rack says definition of summer, for summer tires, is average daily temps > 60 degrees and average nightly temps > 50 degrees)
I dind't get winter tires, becuase it doesn't snow THAT much, but it does get cold/wet for quite a while, so I just got a set of UltraHighPerformance All/Season tires. Worked well for me. I didn't notice that much of a drop in performance, while driving. I do drive fairly spiritedly/aggressively, but I don't track the car or anything. I also survived the recent snow storm, where we got 8" or so on our hill.
Old Feb 26, 2007 | 09:43 PM
perfectmax's Avatar
Dude, get a beater! I got a 1994 4runner with 130k miles and it runs like a champ. Bought it for $3k.
Save your G!
Old Feb 26, 2007 | 10:25 PM
JABG35x2's Avatar
If luck is against you, even with a set of snows best to carry cables with you, as many times with heavy snows they won't let you over without some sort of traction (cables/chains), without having four-wheel drive. Then you're sitting at the bottom of Snoqualme for many hours. Maybe 17" will give you enough clearance, don't know though.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
TurTLe*
Sep 29, 2015 01:43 PM
