SUPPLEMENTAL AIR BAG WARNING LIGHT (on)
Old Jan 21, 2007 | 10:22 PM
Beebo's Avatar
Question SUPPLEMENTAL AIR BAG WARNING LIGHT (on)
SUPPLEMENTAL AIR BAG WARNING LIGHT what is that i looked in the oener's manual. all it said was the air bags may not operate properly. why do the air bags stop working and if i take the car to infiniti is it under warranty
Old Jan 21, 2007 | 10:41 PM
jjyellow's Avatar
There is a defect in one of the airbag sensor, that may cause the airbag to not function in case of an accident. It is covered under warranty. I am bringing mines in tomorrow to get another one replaced. This is my second airbag sensor to go bad
Old Feb 1, 2007 | 01:09 PM
fbw5595's Avatar
Do these parts ever go out of warranty? Mine came on today.
Old Feb 1, 2007 | 01:15 PM
Spoonster's Avatar
What year are your guys' G35?
Old Apr 23, 2007 | 03:40 PM
igramwest's Avatar
The Airbag light went off on my wifes 04 G35 sedan. Took it in an they replaced the passenger air bag module. The next day the "Service Engine Soon" light come on an they had to replace on of the O2 sensors. The next day after that the "SES" came on again, they reset the computer and sent me onmy way. The light has come again they replaced the O2 sensor again and the light came back on again over the weekend. Car is at the dealers for the 4th time in less than 2 weeks.
At this pont i'm begining to think that when they replaced the air bag module that something came lose or they damaged something.
Any one else experience anything like this?
Old Apr 23, 2007 | 04:00 PM
dream_G35's Avatar
my airbag light is blinking (little guy with seatbelt and airbag deployed-RED), just turned the car on today and noticed. I'll be calling Infiniti later is there anything, reset maybe I can do myself to try and get this light away?
Old Apr 23, 2007 | 04:29 PM
LjN_728's Avatar
^ Yea there's a way to reset it yourself but if the warning light is coming on on its own, meaning you didn't tamper with the console, I'd take it into the dealer for inspection.
Old Apr 23, 2007 | 04:36 PM
dream_G35's Avatar
Just got off the phone with a tech and he said if it's flashing, there is probably something light on the seat such as a cell phone and files/papers in my case and the light blinks to warn you that the airbag wont deploy due to not having weight on the seat (safety measure for babies/small children to be in backseat) After awhile the light should go off, IF it stays on steady then to bring it in for a check-up. Never had this happen before though??? i think i was just fed a huge bowl of BS
Old Apr 23, 2007 | 04:48 PM
bokchoy's Avatar
I've had this happen to me twice...
The first time was about a year ago and Infiniti indicated it was a faulty sensor and had it replaced...
The 2nd time (about a month ago), Infiniti blamed my CompuStar Car Alarm/Starter. They said they reset the sensor and it should be fine, but I should have my $700 accessory removed.
I think my Infiniti Dealer is giving me the run around as my professional alarm installer had installed my system in a way to not impact factory settings, anyone have any suggestions as to how to tell Infiniti they're full of BS?
Old Apr 23, 2007 | 08:24 PM
Algy's Avatar
you can lemon law your vehicle if its been in there more than once in a month.
Old Apr 24, 2007 | 11:29 AM
LjN_728's Avatar
Are you getting full yet? That's a bunch of bs bro. Your passenager seat airbag sensor won't even detect if it doesn't meet the weight requirement, which is like around 80lbs. Fine, remove everything off the seat and see if it still happens.
Old Apr 24, 2007 | 11:47 AM
jgainnm's Avatar
Simply not true.
More attempts to fix the same warranty problem are required, and more time is usually allowed (although it differs between states).
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
.cakestar
Engine - Intake/Fuel
Aug 25, 2015 03:17 PM
mjfenix
Jul 17, 2015 02:07 PM
ZacDesu
Jul 14, 2015 11:13 PM
