Wheel Hub Centric Rings
Old Feb 1, 2007 | 10:28 PM
ELE's Avatar
ELE
anyone use Wheel Hub Centric Rings before?....im just wondering if u can use it with the spacer?....
Old Feb 1, 2007 | 10:43 PM
redlude97's Avatar
yes if the wheel spacers are hubcentric
Old Feb 1, 2007 | 10:47 PM
Keith N's Avatar
From what I've read, you won't need them with the Eibach or HR wheel spacers (they're already hub centric). On the Kics, the hub centric rings are around $12 a piece extra. IMO - you'll be good with the 25mm front and 30mm rear.
Old Feb 1, 2007 | 10:50 PM
papiloco21's Avatar
yes you do need them with the spacer...spacer goes onto axle....then ring on the spacer...this is so center bore fits good with wheel.
Old Feb 1, 2007 | 10:54 PM
redlude97's Avatar
hub rings are to make aftermarket wheels with larger center bores hubcentric
Old Feb 1, 2007 | 10:56 PM
ELE's Avatar
ELE
Bingo.....cuz my new rims center bores r larger.....thats' why im asking....but im not quite sure if i can put that onto the hubcentric spacer?....
Old Feb 1, 2007 | 11:18 PM
ttrank's Avatar
Grocery getter
I have used them on most of my aftermarket wheels.
Old Feb 2, 2007 | 12:42 AM
papiloco21's Avatar
if spacer has same size bore as oem hub, yes
Old Feb 2, 2007 | 01:03 AM
ELE's Avatar
ELE
my rims HUB 79.5 ...and the ring im goin to get is, the OutsideDia is 78, and insideDia 66.1 which is same as the oem and the spacer.....
and that 79.5-78=1.5....is that gonna work?....
Old Feb 2, 2007 | 01:07 AM
papiloco21's Avatar
yeah good enough, better than running it without the ring...if anything maybe a little teflon tape to close up remainng gap
Cajuncowboy
Jun 21, 2021 09:47 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
teamghost
Jul 28, 2015 04:52 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
