Crack'd my cf hood
Old May 24, 2007 | 02:42 AM
  #31
ttrank's Avatar
Grocery getter
Mine already was painted, the crack is like a 12" circle and will need some major re-work. Summer project.
Old May 24, 2007 | 09:50 AM
  #32
g7x5's Avatar
mine was just the resin, the cf wasn't touched, it needs to be re-enforced underneath, and i'll have to mod my latch to go even higher so i don't have to press as hard.
Old May 24, 2007 | 12:07 PM
  #33
verbal assassin's Avatar
stronger then steel my azz. haha.
Old May 24, 2007 | 12:14 PM
  #34
Rphillips6487's Avatar
well im ordering mine next week, hope I dont run into problems
Old May 24, 2007 | 12:52 PM
  #35
ttrank's Avatar
Grocery getter
The carbon fiber is. The resin isn't...
Old May 24, 2007 | 12:53 PM
  #36
ttrank's Avatar
Grocery getter
Be careful and if your hood is hard to close, make sure anyone who tries to close knows it can crack if you push too hard.
Old May 24, 2007 | 02:37 PM
  #37
^^alright ill keep that in mind, thanks for the heads up
Old May 24, 2007 | 03:54 PM
  #38
MIAG35's Avatar
I have had lots of carbon fiber parts on my other vehicles and have only had minor problems, and usually (always ) they were my fault. If installed correctly and taken care of they will be fine. As previously stated the resin is very brittle but the weave is very durable.
Old May 24, 2007 | 03:56 PM
  #39
MIAG35's Avatar
The hood should never be hard to close, if it is it's not installed properly. The latches can be modded to fit just right, we had to fab one for my bro's Z.
Old May 24, 2007 | 04:17 PM
  #40
g7x5's Avatar
if anyone has modded a latch other than repositioning it please take pics because i moved mine to the highest position and i still had to push on the hood to close
Old May 24, 2007 | 04:39 PM
  #41
MIAG35's Avatar
I will take pics of my bros latch and post them on Tues. We tried slotting the holes to allow more movement, but it just didn't look right so we ended up cutting and welding a new piece on to the latch. Works perfect.
Old May 24, 2007 | 06:06 PM
  #42
ttrank's Avatar
Grocery getter
I would have had to fab up a new one for mine. It was always tight and the custom intakes I made behind my grille didn't help things either.
Old May 31, 2007 | 07:20 PM
  #43
g7x5's Avatar
do you have any pics of it yet
Old Jun 1, 2007 | 10:16 AM
  #44
MIAG35's Avatar
nope my bros car is in the shop getting a clutch install I will post them when I see the car again. It's really not that difficult the problem is that the latch did not come up high enough so we slotted the mounting holes, just use bigger washers when you bolt it up again. That's the easy fix.
Old Jun 2, 2007 | 10:46 PM
  #45
GinFLA's Avatar
owie!
