which intake should I go first!!!?
Old Feb 3, 2007 | 01:50 PM
ksj4340's Avatar
Finally, I got some $$ left, so I could buy an intake system.
should I go with NISMO
or INJEN
or AEM
or combination with JWT POP + Z-tube?
and are all Z-tube work same? (polished, carbon fiber, regular z-tube)
And I found these on ebay. should I buy one of these?
http://cgi.ebay.com/ebaymotors/20HP-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/PERFO...spagenameZWDVW
And last question, (sorry guys.. )
which stabilizer sway bar should I get!?
I want you guys' advise!!! Thanks!
Old Feb 3, 2007 | 01:58 PM
ndlive's Avatar
stillen intake + stillen ztube! from your choices, popcharger.
and do i really need to tell you about $10 "chip"? ppl spend hundreds and hundreds for 20 hp... only if we could spend $10 and get 20 hp
Old Feb 3, 2007 | 02:04 PM
filanj's Avatar
ROFL at the piggyback switch. If anything that MAF extender will retard A/F timing.
how about you buy my MD 1/2" spacer and see some real power gain instead of some lame CAI sound. for the amount you'd spend on a CAI you can buy my spacer and a stillen Z-tube.... $50 more and you have yourself a K&N cone filter.
Old Feb 3, 2007 | 02:05 PM
filanj's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...7257&rd=1&rd=1
gary c's Avatar
Intakes..........
My choice Stillen CAI and Z-Tube......next MotorDyne 5/16" spacer and then
a cat-back system.........all these mods work togeather!
Old Feb 3, 2007 | 03:20 PM
dcityjatt's Avatar
If your car is is 5AT, then get the stillen cold air box with ztube.
If your car is 6MT, then get the Injen cold air intake.
Old Feb 3, 2007 | 03:22 PM
Nismo G's Avatar
wow here we go again....
I would say injen or nismo, but im not going to bother to write anything.
-sean
Old Feb 3, 2007 | 04:19 PM
bull3t's Avatar
i say get the stillen cai with z-tube...the stillen system is similar to our oem setup which is already a good intake, but it adds a big cone filter that gives you
that intake sound and probably little to no gain...alot of 6mt's with injens experience problems, like the car dying when you put it in neutral on the freeway...
Old Feb 3, 2007 | 04:23 PM
bull3t's Avatar
Hotchkis or Stillen is what i would get...but there are other good ones out there too
Old Feb 3, 2007 | 04:29 PM
AAClaire420's Avatar
HKS hi flow or stillen for an 06 6mt?
Old Feb 3, 2007 | 04:33 PM
PEtaG35's Avatar
+1 Hotchkis Sways
+1 Stillen Popcharger/Airbox
-1 Ebay Power Chip, That piggyback relay will most likly only cause problems. $1 for 20hp?! but from what i hear the chip relays false info to the MAF sensor making the MAF read the air coming in to be around 30 degrees but that in turn hurts your fuel economy
Old Feb 3, 2007 | 05:01 PM
logik05se's Avatar
had z-tube/pop charger....have injen now.
injen > ztube/pop charger.
Old Feb 3, 2007 | 05:30 PM
Rphillips6487's Avatar
injen intake hands down, intakes dont give performance..they give sound
in which case, most will agree injen sounds the best
Old Feb 3, 2007 | 06:06 PM
hien.nguyen80's Avatar
ZTUBE P/Charger won't break the bank
Old Feb 3, 2007 | 08:54 PM
truplay8's Avatar
THE BATMOBILE
injen
