Info on Offset specs Please...
Old Feb 15, 2007 | 10:36 AM
AznTriniBwoy's Avatar
Hi Guys,
2006 G35 Coupe AUTO
I got the 19's stock on the car....so i am assuming that i got this package on my auto.
The G35 Coupe 6MT and Sport-Tuned Suspension Package equipped models offer 5-spoke, 19-inch forged aluminum-alloy wheels with P225/40YR19 tires in front and P245/40YR19 tires in the rear. The Sport-Tuned Suspension Package also adds a standard Viscous Limited-Slip Differential (VSLD). All G35 coupes feature a standard Tire Pressure Monitor System (TPMS).
I have 4 sets of 225/55/17's that i am picking up today from a tire shop and i have to pick out the rims as well, for my winter setup. Seeing that around the GTA, the roads still got ice and snow on the roads, i am carrying them over to the dealer to install them as well.
Because of this, we will not have the chance to try on the different rims on the car. So i need to know what kind of offsets for the rims i will be looking at so that I can tell the tire guy and therefore narrow down the choices.
I dont want to take the tires and rims to the dealer and then it does not fit on the car based on the offsets etc.
I need to know the EXACT or range of offsets that I can put on my 06 AUTO coupe so that I will know what kind of rims I can pair with my Dunlop WinterSport M3's.
Stock for me: 225/40/19 FRONT and 245/40/19 REAR
Winter Setup: 225/55/17 ALL AROUND
Is the below accurate? I bolded what I though I could put as an option on my car.
Based on that thread, I should go to the tire shop with this infor correct?
19" 5 split spoke (2005+ Coupe optional)
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
Sorry I don't know anything about these offsets type thing. New at this
https://g35driver.com/forums/showthre...ghlight=offset
17" 5 spoke (model??)
Front & Rear: 17"x7" +40mm offset 5x114.3mm (5x4.5in) bolt pattern (aka PCD)
17" 6 spoke (model??)
17" 7 spoke (2005+ Sedan std)
Front & Rear: 17"x7" (+40mm offset)???
18" 7 spoke (2003/2004 optional 2005+ Coupe std)
Front & Rear: 18"x8" +30mm offset
18" 5 split spoke (2005+ Sedan optional)
Front & Rear: 18"x7.5" (+30mm offset)???
Thanks in advance.
Picture Share
Feb 4, 2018 12:41 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
