Grounding kit?
Old Feb 15, 2007 | 10:58 PM
lekker_droom's Avatar
Grounding kit?
I need to get some opinions, facts would be better, on wether a grounding kit is a waste of money on a manual tranny?
You can see my mods so far in my signature. Let me know if you guys think a Gordgees would do anything for me. Not just horsepower but making the car run happier.
Old Feb 15, 2007 | 11:13 PM
BadBoy06's Avatar
^^^ I think you'll find mix results on this 1
Old Feb 15, 2007 | 11:55 PM
Calvin's Avatar
Overglorified Altima
on a 6mt, yes.
spend your money on something else.
Old Feb 16, 2007 | 01:13 AM
wilksoner's Avatar
i did the same post a while back and everyone says dont bother
Old Feb 16, 2007 | 02:03 AM
cool.
hey wilksoner, you happy with your mrev2?
super street or somebody just did an mrev2 install in their "power pages" section on an '06 350z. The dyno showed a gain of approx. 15 lb. ft. of torque. low end torque too. that's what i want more of.
Old Feb 16, 2007 | 02:09 AM
Calvin's Avatar
Originally Posted by lekker_droom
cool.
mrev2 + 5/16" spacer is the way to go..
i wouldnt do it with the skunk2
Old Feb 16, 2007 | 03:03 AM
redlude97's Avatar
+1, MREV2 and Skunk2 5/8" spacer is too much volume in the manifold
Old Feb 16, 2007 | 11:21 AM
b00stedjustin's Avatar
it will make everything run smoother but wont give you much difference besides this. Grounding kits are really basic, you can purchase an ebay special for 10 bux and have the same results that you would get with any other kit (most are priced around 150 bux) on the market.
Old Feb 16, 2007 | 02:31 PM
Paperchaser's Avatar
maybe i should posted a thread like this b4 i bought mine
Old Feb 16, 2007 | 02:48 PM
redlude97's Avatar
Quality wire costs more than $10 bucks so I highly doubt you can get the same output, but your idea is good, you can build your own generic kit for much less using quality wiring and connectors for probably $30-50 worth of materials
Old Feb 16, 2007 | 03:53 PM
No, you do get the same results. We used this as an experiment in one of my mechanical engineering classes lol. We had heard from friends that "name brand" grounding kits are the same as the generic ones from other college car buddies at the time. But wanted to prove it. What do you think would actually coast 30-50 bux in materials? They're just wires and connectors lol. I think I would just buy the more expensive ones to have the name, but what can I say I'm a fool to marketing.
Old Feb 16, 2007 | 04:03 PM
Jeff92se's Avatar
Red Card Crew
6MT. Well most of gains people rave about are from the auto guys. But IMHO some of the factory grounds could be improved upon. ie.. battery ground, engine to chassis ground strap and the ign coil grounds. IMHO 8 ga is plenty as that's even 4-5x larger than the oem grounds. I also think DIY is okay as long as you connect the terminals/wires via solder/crimping well.
Old Feb 16, 2007 | 04:05 PM
trey's wife's Avatar
My horns hold up my halo
Go to the local Barnes and Noble and pick up the winter edition of Nissan Sport Magazine. Article by yours truly on just this subject.
Old Feb 16, 2007 | 04:20 PM
redlude97's Avatar
I'm not even talking name brand, I can spend more than $10 on just connectors that are barely decent. A good ring connector costs in the range of $1-2 each, so you do the math. Decent OFC high strand cable in 4 guage is also relatively expensive
Old Feb 16, 2007 | 06:24 PM
GreenGoblin's Avatar
The goblin resurrection
Iwas going to make my own but than decided not to
