Endless CC-A to supercede Endless SS-S
Old Feb 23, 2007 | 06:00 PM
Andy@Performance's Avatar
After working with Kent@Endless USA, we have discovered that the CC-A pads will be a better choice over SS-S. The CC-A uses a carbon ceramic compound that is slightly more aggressive than the SS-S. The CC-A will be slightly more abrasive on the rotor, but compared to the SS-S, there is not too much of a difference. The CC-A pad will be good for spirited driving as well as track and auto cross use. It performs better than the SS-S in every way, of course, with low dust and low noise in mind. Greater initial bite, predictable pedal feel, narrower coefficient of friction. The best part is, the CC-A is only a couple dollars more than the SS-S. Kent@Endless USA and I have decided to start slowly phasing out the SS-S and supercede it to the CC-A.
Anyone who has been thinking about getting the SS-S pads, I strongly recommend that you consider the CC-A instead.
Old Feb 23, 2007 | 08:03 PM
Joshua's Avatar
good news, ive been meaning to get new pads, where can i get CC-A'a
Old Feb 23, 2007 | 08:39 PM
jinubob81's Avatar
Evil Bastard
i'm going to take a wild guess and say... at the OP's website?
it's only a guess, so take it with a grain of salt.
Old Feb 23, 2007 | 09:42 PM
cloud's Avatar
there's something not addressed here. I did some research a month ago before i decided to special order my SSY from Japan.
The CCA works at a higher temperature range. Don't know to what extent the braking power would deteriorate to at low temps though...
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
j-velocity
Nov 24, 2006 09:00 AM
