2003 6mt coupe need help
Old Feb 25, 2007 | 11:01 PM
gcode's Avatar
Does everyone with a 03 6mt car feel unstable at high speeds on the highway. I mean above 80 any movement in the steering wheel it feels very light and I honestly don't want to take it above 120.
I have had alignment done
new back tires (the dealer did tell me the front tires should be replaced because they did not wear evenly, they make a slight noise when I drive).
Hopefully you guys can help. I got my g35 used in sept 05 from a local infiniti dealer. When I got it the tires in back had about 10% in them left.
Recently I just dropped it on tein s techs and got some d-specs. Rides better but the highway is about the same above 80. I know the newer models have the rear active steering or something like that to help it. Is there anything I can do.
Also I wanted to add this is my first rear wheel drive car. I have drove bmw's 3's and 5's. I know this is not a bmw but something is not right. What I mean to describe the problem is when I am driving on a highway the steering is too light. Like if I have to change lanes the car doesn't really feel planted on the ground, changing lanes at high speeds is the worse. I let people drive it and they agree something is wrong.
Old Feb 25, 2007 | 11:22 PM
slikmo22's Avatar
I havent had that problem at high speeds my car feels very stable. Do you have the aero package?
Old Feb 25, 2007 | 11:26 PM
audio_file's Avatar
Wow, never felt that way on mine (clear up to the 155 max)
double check that your tires are inflated correcly (?) could be having two different sets (old front and new rear) is causing issues . . .
why are the fronts wearing un-evenly? did you do a carfax when you bought it?
Old Feb 25, 2007 | 11:30 PM
gcode's Avatar
No the car did not have the aero package and I did do a carfax on it nothing bad was on it only had one owner and 18k on it. The front tires look fine have about 50% life in them but somehow they wore out unevenly. And when I got it did this and it was on the orginal tires. (fronts are still and the rear are some cheap ultrasport tires I got)
Old Feb 25, 2007 | 11:32 PM
gcode's Avatar
is the aero package the spoiler, splash guards, front chin. Because I have that but I added that recently.
Old Feb 25, 2007 | 11:55 PM
audio_file's Avatar
yes
if the front tires were wearing un-evenly before you put on the springs then it had to have had a suspension/allignment issue.
Old Feb 26, 2007 | 01:14 AM
VQ Hotness's Avatar
What size tires are you running? xxx/xx/xx
Old Feb 26, 2007 | 06:06 AM
FAST1's Avatar
1. The condition that you describe is absolutely not normal.
2. You have a safety issue.
3. Make an appointment as quickly as possible with the Infiniti Dealer that sold you the car. Have them check it out thoroughly.
4. In the meantime don't drive your car over 70.
Good luck.
Old Feb 26, 2007 | 11:55 AM
gcode's Avatar
18's
245/45 in the rear
225/45 in the front
Old Feb 26, 2007 | 03:35 PM
audio_file's Avatar
Good luck.
^+1 not normal, sounds dangerous- at 35mph OR 80mph. Get it fixed, you are missing out on the fun that your g is designed to deliver.
Old Feb 26, 2007 | 03:38 PM
Hi-TechG35's Avatar
I don't have that problem either but you may want to get a car fax report and make sure your car was not involved in any accidents. My boy frought a G and the car was doing the dog leg. Come to find out the car was hit and there were some suspension problems that were not fixed correctly so he ended up returning the car.
Old Feb 26, 2007 | 03:42 PM
redlude97's Avatar
what are your front and rear toe settings?
Old Feb 26, 2007 | 05:10 PM
g35dalf's Avatar
Kudos to the safety mined people here.
Let a professional check the car out before you end up wrapped around a pole.
Old Feb 26, 2007 | 07:27 PM
in2win's Avatar
check your tire pressure, that is huge an at those speeds any minuscle problem is magnified throughout the car.
joedaddy1
Jul 28, 2015 02:58 PM
Kal Hamm
Jul 24, 2015 08:55 AM
realtalk21
Jul 20, 2015 09:07 AM
driftsucky
Jul 15, 2015 12:38 PM
