Is it stupid to get Brembo brake system on a 5AT coupe?
Old Mar 2, 2007 | 02:29 PM
  #31
Jeff92se's Avatar
Red Card Crew
They are a direct fit? And the G35 rotors can be used??
Originally Posted by IvoryGT
ahhh...just do it if you got the dough...I remain that the used STI ones are cheaper than used G35 ones with bigger pistons...and they look cool!
Old Mar 2, 2007 | 02:32 PM
  #32
redlude97's Avatar
I would guess they bolt up directly because most likely brembo uses a universal mounting spec, but make sure the center of the caliper is aligned with the center of the rotor
Old Mar 2, 2007 | 02:34 PM
  #33
Jeff92se's Avatar
Red Card Crew
I'm concerned about the rotor hat offsets. I do know Mitsubishi uses similar hat offsets to Nissan. Do the rears fit also?
Old Mar 2, 2007 | 02:37 PM
  #34
redlude97's Avatar
Yes, thats what I meant by centering. I know STI's run very high offsets compared to G's which is why I would be concerned with fitting
Old Mar 2, 2007 | 02:43 PM
  #35
Jeff92se's Avatar
Red Card Crew
The thing is if the offsets aren't right. It's very difficult to find a safe way to adjust them
Old Mar 2, 2007 | 02:48 PM
  #36
wilksoner's Avatar
i say go for it
Old Mar 2, 2007 | 03:21 PM
  #37
ma_sha1's Avatar
OE Brembo weighs a ton, way heavier than non brembo.
Looks nice, but only going to make your car go slower if not tracking your car.
Go with Willwood 2 piece rotor & forged calipers, much lighter than OE & cheaper.
Old Mar 2, 2007 | 03:24 PM
  #38
fhumphrey04's Avatar
For how expensive the used brembos are here you mise well spend a little more and get a nice set of stoptechs or something. I looked into it for my AT and I cannot justify that much cash for a stupid set of brakes, considering they are as much as a set of decent rims.
Old Mar 2, 2007 | 04:07 PM
  #39
htownboy's Avatar
define not even close? 05-06 single piston floating calipers have very similar panic stop braking distance numbers to the brembos. Face it, the cars are limited by TIRES, not brakes. We aren't talking high end cars, of course the brembos are better, but on the street, hardly. Both setups can easily lock up the wheels where abs kicks in so stopping becomes almost solely dependant on tire compound and weight distribution
Your so full of bull!
Your only defensive because your year model G did not have Brembo's, go on admit it!
Here we go, let the flames begin...
I am not saying Brembo's are better, I am saying multi-piston fixed calipers are better and feel better in every way. Brembo's just happen to use this design as all of your best brake parts manufacturers do...
There is only one reason not to use multi-piston calipers and that is to save money. You can argue until you explode but the multi-piston brakes will always be better and feel better and will cost you some extra $.
Now, can you come up with any more arguments or will you just let it go? Let the guy go and upgrade his brakes, he will appreciate them!
Old Mar 2, 2007 | 04:14 PM
  #40
^^ very true
On the street its not going to matter much either way, but on the track the brembos will not fade much at all in comparison.
Its all about the looks though
  #41
Canadian's Avatar
Canada, eh?
I plan on getting a BBK after my TT install, I'll prob go with some stoptechs
Old Mar 2, 2007 | 04:34 PM
  #42
Derek173's Avatar
Having swapped my stock brakes for brembos, I can tell you that regular street stopping distances will not improve much if at all. However on the track the brembos make a big difference.
The Brembos also have a more linear feeling when braking. The stocks felt like an on/off switch.
Old Mar 2, 2007 | 10:17 PM
  #43
edindaclub's Avatar
is this gonna fit on my G ??
check this out http://cgi.ebay.com/ebaymotors/Bremb...em290089769025
Old Mar 2, 2007 | 10:44 PM
  #44
Derek173's Avatar
probably not, you might be able to make it fit.
Remember brakes are more then calipers and rotors, you need something designed to work with your car. A good brake system is designed with your cars master brake cylinder in mind.
Dont go cheap on brakes! if you are on a budget find some used brembos from a 350z/g35
Old Mar 2, 2007 | 10:54 PM
  #45
Gdubcp's Avatar
4 pot brembo will make a big difference on either street or track use. First hand exeprience!
Like Jeff said, if you are going to upgrade your front make sure you do something with the rears, or else the brake balance will be off.
Especially if you have upgraded wheels let say from 17-19.
You will definitly notice a difference with 4 pot caliper instead of the usual 1-2 pot pistons.
I used to track my M3 on a monthly bases and daily drive the car. Trust me on this! BBK make a DIFFERENCE
