Motor Oil Used?
German Castol syntec 0w-30 used oil analysis on a G35 coupe
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">code:</font><hr /><pre style="font-size:x-small; font-family: monospace;">Element This Last 2nd to Last Universal
Sample Sample Sample Averages
Aluminum 2 1 2 3
Chromium 0 0 0 1
Iron 5 2 7 11
Copper 5 3 6 7
Lead 2 1 3 5
Tin 0 0 1 1
Moly 4 3 1 75
Nickel 0 0 0 0
Manganese 0 0 1 0
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium 1 0 7 1
Boron 0 1 1 64
Silicon 8 7 9 11
Sodium 9 8 1 7
Calcium 2643 2504 2520 2296
Magnesium 106 111 103 115
Phosphorus 687 660 635 705
Zinc 857 762 789 840
Barium 0 0 0 0
TBN 2.6
Test : Vis Flash Fuel AFZ H2O INSOL
@210F Deg F % % % %
Shd Be: 58-65 >385 <2.0 0 <0.1 <0.6
This: 61.9 415 <0.5 0.0 0 0.3
Sampl
PARTICLE COUNT DATA
2 microns or less = 833
5 microns or less = 308
10 microns or less = 85
15 microns or less = 33
25 microns or less = 7
50 microns or less = 0
100 microns or less = 0[/code]</blockquote><font size="2" face="Verdana, Helvetica, sans-serif">EDIT: The ISO Cleanliness Code for this PC data is 15/12.
Aluminum 2 1 2 3
Chromium 0 0 0 1
Iron 5 2 7 11
Copper 5 3 6 7
Lead 2 1 3 5
Tin 0 0 1 1
Moly 4 3 1 75
Nickel 0 0 0 0
Manganese 0 0 1 0
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium 1 0 7 1
Boron 0 1 1 64
Silicon 8 7 9 11
Sodium 9 8 1 7
Barium 0 0 0 0
TBN 2.6
@210F Deg F % % % %
Sampl
PARTICLE COUNT DATA
Originally Posted by Derek173
some info for you guys, Mobile1 is no longer a true synthetic
Mobil sued Castrol for calling their oil a full synthetic. Which according to Mobil it wasnt a full synthetic like M1 since its not made from a Group IV base stock.
They lost the case, so they decided to start using the cheaper base stock just like Castrol,pennzoil etc. Why make a real synthetic that costs you more money to make then the competition who is charging the same?
German Castrol Syntec 0w-30, Amsoil, redline are some of the few remaining TRUE synthetics( Group IV). The other Castrol syntecs, penzzoil platinum and now Mobile 1 are not TRUE synthetics. They are hydrolocked Group III oils.
I just purchased the mobil oil from costco and it says FULL synthetic. I remember awhile back ago it use to say part synthetic but now FULL. Are u sure they didnt change it?
anyone try royal purple... I saw adds stating it increased hp by +9hp.
is the german 0w30 oil good for use in hot places, ie florida in the summer?
I just use whatever the dealership puts in my car... i know its bad but I do'nt have the stuff at my apartment to change it myself. Is it hard to do on the G?
thanks
thanks
thanks
thanks
copy and paste from the German Castrol FAQ
Is it "thin"? Come on, 0w-30 has to be watery.
NO! Please don't completely buy into that myth.
At cold temps, the 0w weight correlates to cold cranking viscosity.
That means GC will still flow at cold temps. (Which is a good thing!)
At operating temps, the 30 weight is actually close to a 40 weight.
GC is one of the thickest 30 weight oils around.
I don't want to go into too much detail about this here. It can be very confusing.
My point is, GC is not "thin" in most temperatures that we use our cars in.
M1 5w-30 is actually thicker then M1 10w-30 at operating temperature.
For those worriesd about running a 0W oil
Thin Oil Myth
Created: April 10, 2006
Disclaimer:
All the temperatures here are in celcius.
Short answer:
0w-30 and 5w-30 can be thicker than 10w-30.
Long answer: Read below.
Really Basic (but not so intuitive) information:
I'm sure we have all seen 5w-30, 10w-30, 10w-40, 20w-50, but what does it mean?
When talking about viscosities, you must state the temperature.
Lets break this up into two categories: hot and cold.
Xw-20, Xw-30, Xw-40, etc (HOT!)
This is your oil's hot viscosity. The viscosity is measured @ 100c.
This number is relative when the engine is warmed up.
The most common unit is cST. The larger the number, the "thicker" the oil.
Examples
A "30" weight is between 9.30-12.49 cST @ 100c.
A "40" weight is between 12.50-16.29 cST @ 100c
"Why isn't 5w-30 or 0w-30 thin?"
I think a real-life example will help.
Lets compare Mobil1 5w-30 to Mobil1 10w-30.
First the Hot (100 c) setting
Straight from Mobil1's datasheet (Looked on April 4, 2006):
5w-30 = 11.3 cST
10w-30 = 10.0 cST
Looks like the 5w-30 is thicker! (Notice how both oils are a "30" weight)
Now lets look at the cold setting
Based on the 5w and 10w specifications:
5w-30 = 6600 cP or less @ -30c
10w-30 = 7000 cp or less @ -25c
Looks like 5w-30 is thinner than 10w-30!
We can conclude that:
5w-30 is thinner than 10w-30 at -25c.
5w-30 is thicker than 10w-30 at 100c.
The above implies that 5w-30 thins out less than 10w-30 as temperature increases.
My main points are:
0w-30 can be thicker than 5w-30.
Thin Oil Myth
Disclaimer:
Short answer:
Examples
5w-30 = 11.3 cST
10w-30 = 10.0 cST
My main points are:
Originally Posted by izmir41500
mobile 1 full synthetic. 5w30
there was the same thread on the same subject. try the search function.
