dead battery + jump = dead console?
Old Feb 24, 2007 | 08:01 PM
rs2183's Avatar
sooo my car has been sitting in the cold and when I went to turn it on, the battery was dead. Got some jumper cables finally a day or two later and jumped it right up without any issues.
However, the entire console where the cd player is including the heat, ac, fm, tape, all those buttons are unresponsive. The car turns on and off fine. The steering wheel controls won't power on the stereo either. I cannot adjust the temperature because those buttons are unresponsive as well.
The cd player display is blank and the orangish hue is there on the buttons, but it seems to be a tad bit dimmer. Anyone else experience the same problem? I hate going to the damn dealer but looks like it may be the only option.
any ideas?
Old Feb 24, 2007 | 08:13 PM
durtee_south's Avatar
check your fruses. i know you said you have somewhat of an orange hue..could that just be some bleed? i dunno, good luck
Old Feb 24, 2007 | 09:24 PM
BadBoy06's Avatar
wtf..from a dead battery..has to be something else
Old Feb 24, 2007 | 09:27 PM
ARTofDESIGN's Avatar
First, Unplug your battery overnight and then try it the next day.
If that doesn't do it my money is on fuse....
Old Feb 25, 2007 | 01:34 AM
wilksoner's Avatar
nope but its got to be a fuse i would think dont leave ur car sittin in the cold for so long id just start it and let it warm up for a lil bit every 3 or 4 days
Old Feb 25, 2007 | 03:44 AM
duggy's Avatar
You could have shorted out something when you jumped the car.
Old Feb 25, 2007 | 01:41 PM
rs2183's Avatar
i don't know what else it could be... i haven't done anything with the thing
Old Feb 25, 2007 | 01:42 PM
rs2183's Avatar
yeah shoulda started it up here and there
Old Feb 25, 2007 | 01:49 PM
bondzilla's Avatar
Were you the one that jumped it? Ive had issues at my shop where people have jumped the terminals *** backwards which can do some damage
Old Feb 25, 2007 | 02:13 PM
rs2183's Avatar
it was jumped backwards first, not by me, retarded cousin.
What kind of damage am i looking at?
rs2183's Avatar
found the fuse box by the battery... someone want to give me a crash course for what i'm looking for?
Old Feb 25, 2007 | 02:29 PM
LT1 SS's Avatar
It should say what fuse does what on the fuse box. When you pull a fuse out just look at it to see is the metal wire is broken. If it is replace it with a fuse of the same amp rating. Also check the fuses in the drivers side kick panel.
Old Feb 25, 2007 | 02:33 PM
rs2183's Avatar
Thanks, just read somewhere that our cars come with spare fuses and a puller... would you happen to know where they put this?
Old Feb 25, 2007 | 02:50 PM
LT1 SS's Avatar
The fuse puller is in the kick panel. It's a white plastic piece that has a hole in the center. Push it over the fuse and pull it out. The lid for the fuse panel boxes will tell you which ones are the spare fuses.
Old Feb 25, 2007 | 04:08 PM
rs2183's Avatar
Thanks bud.. looks like every single fuse in the box by the battery is fried. I'll go pick up some fuses. For those that are in the box looking things, do I have to worry about them? How do I check if they need replacing?
I have to go pick up a battery now as well.
Thanks for your help.
