is my car safe to drive??
My car is 91K miles now and been using M1 synthetic since 10K miles. Change oil mostly at 5K miles, sometimes up to 5.5K miles (heavy foot most of the time). Car still smooth (knock on wood).
You'll be ok with that much of mileage, but just change oil as soon as you can as one said above.
Originally Posted by cchaorule
i have been tryingh to change my oil for a while now.. its been 5300 miles since my last oil change.. i use mobil1 synthetic 5w-30.. i usually change it every 5000 miles.. my friend told me to not drive my car anymore because he said there might be oil sludge problems.. what do you guys think?? is it safe to drive??
Much to my surprise, if you open your owners manual, theres a chart in there somewhere that says regular service intervals. The "max" we can apparently go on one serving of motor oil is 7350 miles without a change. Now, obviously, as with all things, your exact mileage may vary before sludging becomes an issue, but I tend to try to change @ 3000-3500 just to be on the safe side. Theres no reason oil would have problems at 5k, unless you drive your car like its going out of style. If your drive is mostly highway though, 5k highway really isnt as much as youd think on oil these days.
I'd change my oild every 3k miles, some time few hundred miles more or less. At the end of 3K miles, I would inspect the oil color and texture with the oil stick...my boss thinks that I should change every 5K miles but that would over kill my engine from the way I drive and the way his drive!!
pd
pd
Originally Posted by sliderg35
I change my filter every 6,000 km (3,600 Mi), and I change the oil every 12,000 km (7,200 mi) using Mobil 1.
Originally Posted by b00stedjustin
Don't drive it again before an oil change!! Your car will explode!!!
hopefully you are one of the lucky ones
Originally Posted by overdrve
How do you change your filter without doing an oil change? Just curious...
i change my oil myself every 3000 miles/3 months with the oil infiniti uses. SORRY DONT MEAN TO STEAL THE THREAD!!!!! But what is the best synthetic oil to use??? Thanks
But there's zero evidence to support the belief that 3K mile oil changes do anything to promote longer engine life on modern cars using synthetic oil or even a synthetic blend that's used by Infiniti. My son is now driving my old '95 G20 with well over 200K miles on the odometer, and for the last 12 years we've been changing oil every 7-8K miles. I did a compression test on the cylinders last summer and they all read nearly identical. I asked my local independent mechanic how long the engine will last, and he said that he wouldn't be surprised if I got 300K before a rebuild would be required.
Changing oil more frequently won't hurt anything other than your wallet, but I really doubt that it extends the life of the engine. It seems like those Jiffy Lube comercials have scared the hell out of millions of car owners who are now willing to throw away $40 for a needless oil change.
Hasanbaloch
Feb 29, 2024 08:45 PM
