unsure symbol light came on the car..
Old Mar 6, 2007 | 01:42 PM
vhtran's Avatar
Originally Posted by aHero4Eternity
nope
Thanx
Old Mar 6, 2007 | 04:43 PM
M4Gunner's Avatar
Originally Posted by Toofy
hmmm it seems good.. i was just checking and someone mentioned that it comes on when its cold outside and this morning it was freezing winds so im assumin it should be gone lata when i leave work.
thanx again tho bud atleast i know its no biggie!
yeah, when i bought mine, i was getting the same deal (on dealer tire pressure) so i raised them to what i like, and have had no problems since. lemme guess, your light goes away after a few minutes of driving?
Old Mar 6, 2007 | 09:26 PM
GWord256's Avatar
I got that light just before I went for the 3750 checkup. Some d1ck must have bleeded one of my tires because the pressure was at 7psi when I drove it to the gas station on the way to the oil change. At least it wasn't a nail/hole, you can't patch a high performance tire (well... it's highly discouraged).
Old Mar 6, 2007 | 11:27 PM
avs007's Avatar
Originally Posted by DanejaPwnz
yeah that sign is for tire pressure. In the winter its pretty regular to see that since we all know heat causes air to expand and cold makes the air contract. you shouldn't worry about that too much unless your tires are losing air consistently
You guys getting air at the gas station? I noticed most gas stations don't bother bleeding moisture out of their tanks, nor do they have inline line-dryers. Moisture in the air, is bad for your rims, and will cause greater pressure fluctuations with temperature... I noticed the gas stations near me, have so much moisture in the air-tanks, that water literally streams out with the air.
One of the reasons people push Nitrogen so much, about it fluctuating less... Actually has nothing to do with the Nitrogen. It's actually because the memranes they use to extract nitrogen, happens to also separate moisture from the air at the same time...
Anyways, I have my own 26 gallon tank and compressor, and I installed an inline line dryer... I haven't had the TPS come on in the cold since I started filling my own tires.
And FWIW, they come on at 28 pounds, not 34.
Old Mar 7, 2007 | 06:25 AM
Toofy's Avatar
acually its still going on since yestorday morning. IT is however freezing here in new york for the past two days. Weather is around 14 - 25 degrees from morning till mid day and lower at night.
Im sure its no biggie but i dont like seeing the little light come on right after i buy the car u know?
P.S if the light is on ( which it is ) how do i know which tire needs it? they look fine to me.
Old Mar 7, 2007 | 06:42 AM
akachi's Avatar
some gas stations has air that has tire pressure guage built in.. u could check by that
Old Mar 7, 2007 | 06:46 AM
Toofy's Avatar
i just bought this car last week did not even touch a air tank yet.
Old Mar 7, 2007 | 07:04 AM
Rphillips6487's Avatar
tire pressue, same thing occured in my denali
Old Mar 7, 2007 | 07:05 AM
you shouldnt be conerned, in most cases its due to the tempterature and the way your tires are been sitting. once you drive it for a bit, most likely the light will turn off
Old Mar 7, 2007 | 07:06 AM
akachi's Avatar
yeah.. i also live in NY..
had the warning light up last week on a cold day..
it went away on warmer days
Old Mar 7, 2007 | 07:11 AM
Toofy's Avatar
ok yeah i figured it was that... maybe ill wait cause right now its snowing outside AGAIN so im sure its on afta i get home.
Old Mar 7, 2007 | 07:30 AM
bryanmac's Avatar
Originally Posted by vhtran
Don't want to jack the thread, but for those who have after market wheels (w/o TPS valves). Is there a possible way to shut the TPS light?
You could always do as I did in my broke a$$ college days to my turd p.o.s. cars and pull the bulb out of the dash. Easy fix for those check engine lights, who needs them anyways?lol I don'k know if I would want to tear into my g like that but those idiot lights drive me nuts when they stay on.
Old Mar 7, 2007 | 05:06 PM
M4Gunner's Avatar
Youre just better off checking all 4 tires and making sure theyre all exactly where you want them. what pressure you use is up to you. i played around till i got what felt right.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
