HELP: fuse for power windows
Old Dec 7, 2003 | 02:24 PM
maruchi's Avatar
does anyone know which fuse is for the power windows?
I've checked the fuse boxes (in front of the battery and next to the foot rest), but the labels don't help much.
thanks in advance!
'04 G35 Coupe DG/G 6MT
Prem & Aero Pkgs
Old Dec 7, 2003 | 03:04 PM
maruchi's Avatar
Re: fuse for power windows
I'm having a problem with power windows and locks.
last night to fix a rattle, I pulled the door finisher on the driver side by following the door finisher removal steps somebody posted earlier.
the steps didn't help much when it came to disconnecting the power window/lock switch box from the wires.
instead of disconnecting the wires from the switch box, I took out the IC unit still connected to the wires 'cuz it was easier than disconnecting the wires.
the problem occurred when the IC unit came loose.
the door ****/lock cable tips touched the IC unit and there was this spark and smoke from the unit...dayam.
since then, the power windows and locks don't work with the buttons on the doors, both driver and passenger sides.
however, the power locks seem to work with the remote, but the auto window down feature when the "unlock" button on the remote is depressed for 5 seconds or so doesn't work.
and the windows don't roll down or up when the doors are open and closed.
I'm hoping one of the fuses got shorted.
any help is appreciated.
thanks!
Prem & Aero Pkgs
JLee301
Sep 25, 2015 08:46 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
gatorglaze
Sep 10, 2015 12:03 PM
zcherub
mtlruss
Lighting
Sep 9, 2015 07:44 PM
