Questions and Concerns about my G
Old Mar 6, 2007 | 08:47 PM
avengence's Avatar
Ok so I recently got a G35... I have had it for a few months now. There are some things I recently noticed that I have questions about. Here they are:
1. Squeaky brakes. I got them looked at and they say its cause they got too hot now there is a glaze on the rotor or something. It only happens when the brake is lightly pressed at low speeds. They said I have like 7k lefts on this set of pads so they told me just to wait and they will turn the rotors and change the pads when the time comes... does this sound right?
2. I am getting a click from my car on the passenger side. It sounds like it is the axel click but does the axel click happen even when you are lets say coasting and then hit the gas hard and when you come to a stop? Right now if I take off it clicks and when I stop and it clicks and then sometimes I hear a clang noise... not loud but it sounds like something was hanging under my car and flopping around. Could it be my brakes? I really didnt notice this till I brought my car into get the brakes done. Also does the clicking in the axel hurt it at all?
If anyone has any input about this stuff I would really like to know. I love the car and I guess these are just little problems.
Old Mar 6, 2007 | 10:41 PM
BadBoy06's Avatar
+2 on the above^^^^
Old Mar 7, 2007 | 01:50 PM
avengence's Avatar
Last night my friend confirmed that it was my back right wheel that is clicking. Also I parked on a hill and hit the e brake while in gear to test my e brake and it started squeaking. Could the squeaking im hearing be coming from the back when I am lightly hitting the brakes while coasting?
Old Mar 7, 2007 | 06:11 PM
jocam23's Avatar
I suggest everyone that has a squeaky brake problem to go to the dealer RIGHT NOW AND HAVE THEM REPLACE YOUR ROTORS BEFORE THE SO CALLED BRAKE WEAR CAMPAIGN WARRANTY GOES OUT!.
I'm pissed because I take my car in for an oil change and I get a call from the service guy that I need to spend $575 DOLLARS WTF!!!!!!!!!!!!!!!!!!!!! ON NEW FRONT ROTORS!!!!!!!!!!!I have an 04 coupe that only has 26,000 miles on it. we drive it about 20 miles per day!
Can someone tell me how the brake rotors need to be replaced????????????????
Now the guy tells me that we are not covered under warranty because we passed the 3 year mark for our brakes???????????It was just in 11-06 and my car only has 26,000 miles on it.....
Sorry this is frustrating because evrytime we go fo an oil change, we always complain about the brakes but they tell us that is how the brakes are and you have to press harder to make the sound go away----A BUNCH OF BS.
SORRY FOR THE LONG A** RANT
Old Mar 7, 2007 | 07:55 PM
GR8TG35's Avatar
jocam23....sorry about the warranty expiring.....that does $uck.I would complain to the manager about the response you were given regarding the Brakes.....that seems a little underhanded.
I had my brakes replaced twice in the the 36,000 mile period.
I was lucky, my service guy is really cool, and made it a point to have mine changed out at 19,000 and again at 36,000 so I wouldn't get stuck after the 36,000 miles. But the next one is on me
The axle click is a very common problem with the G35. The dealership had a TSB regarding it.....Unless its a major component that failed, that should not cost much to repair....I believe its a matter of retorqueing the half shaft bolts.
Old Mar 7, 2007 | 11:20 PM
avengence's Avatar
I am no longer under warranty... how much will the axel click be to fix? I am gonna take it there and have them check it out for me.
Old Mar 7, 2007 | 11:21 PM
avengence's Avatar
Oh also... does the axel click hurt anything on the car? I am wanting to get it fixed but I dont know when I will have time next...
Old Mar 8, 2007 | 02:34 PM
avengence's Avatar
I am still confused on if this is actually an axel click problem. It is coming from the back wheel but I cant figure out what the clang noise is when I stop sometimes. I guess I will just take it to the nissan dealership and have them take a look at it... for some reason the nearest infiniti dealership is really far.
Old Mar 8, 2007 | 03:00 PM
BadBoy06's Avatar
You can also take it to a Nissian shop
Old Mar 8, 2007 | 03:41 PM
avengence's Avatar
Yea I am not too sure where the nearest nissan shop is to me.
Detailed Image
Aug 27, 2015 08:15 AM
Detailed Image
Aug 7, 2015 02:10 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
