G35C Driver Side Window Rattling
Ok First off i searched the forums looking for guys with similar problems and didn't find anything that matched my particular problem so here goes.
As the title says the driver side window is rattling and ofcourse i hear it when i drive on rough roads. (symptom)
i also notice the when i open the door the window no longer goes down 10mm it goes down maybe 1mm and if i open the door i can use my hand to push the window down 9mm where it should be. when i close the door the window goes up 10mm as it should.
All other window functions work fine thank goodness. But the fact that it doesn't go down when i open the door plus the rattling is annoying.
has anyone experienced somethign similar to this before?
how do i fix it? i am out of warranty 41k right now 04 coupe
if i have to take off the panel how do it do that?
thanks in advance.
thanks in advance.
my window rattles only when i roll it down and back up while in the car. if i close the window and open and close the door, it goes away. it's weird and if it persists i'll bring it into the dealership
vstypicals
Jul 20, 2015 10:55 PM
