6mt launch & shift techniques
Old Mar 19, 2007 | 10:44 PM
trueskillz12's Avatar
all i have is a z tube and i'm dragging my friend's stock is350 in 2 weeks. i'm pretty curious about that 4.9 0-60 that was published a couple months back.
i haven't exactly had the best luck with launches on the 6mt.
what do you guys normally do?
as i understood it in the honda days it was rev and drop the clutch. but those days are over.
for the launch i was told to rev high and when the light is about to turn green let the rev drop to about 2-3k --> let the clutch go til it catches --> drop clutch --> mash gas
on the shift to 2nd do you guys shift and drop the clutch?
please do share your techniques.
Old Mar 19, 2007 | 10:55 PM
IvoryGT's Avatar
I doubt you are going to win against the 350 unless your friend really can't drive.
But to launch, hold the rev at around 3~3.5K. When the light turns green feather out the clutch while try not to hit the throttle any hard than you are already holding, wait till the car grips, slam on gas and dump the rest of the gears as fast as you can let the clutch out.
Old Mar 19, 2007 | 11:01 PM
mxkon's Avatar
that is350 stands a great chance of beating you. But i have good luck with comming out at a about 3500 rpm, (at least with my tires) just a little bit of a squill and then it digs in and pulls out.
Unless you give some serious practice as to your launch and hope your buddy sucks at driving, that is going to be a tough race from what i understand
Old Mar 19, 2007 | 11:24 PM
i doubt my buddy will have a hard time driving the is350 being he only needs to mash the gas. i just have a hard time taking in all those 0-60 times that every source publishes.
if you do a vehicle comparison on lexus.com, you will find that the 0-60 for the is350 is 5.6
if you just click the is350 on lexus.com you will find that it's advertised as 5.3
to me it's all marketing bull until you really see first hand.
Old Mar 19, 2007 | 11:41 PM
BadBoy06's Avatar
I come up best at about 2800 with very lil tire screamin
Old Mar 19, 2007 | 11:51 PM
bubbletea 4 me's Avatar
Lexus basically under estimated their performance.. just like bmw did with the 335i..nothing to go crazy over. just know they are fast.. very fast.. faster than our cars :/
btw, many people said "hope your friend cant drive"..um.. how can you NOT know how to drive an auto. all the IS350 has to do is stump on the gas and its gone.. maybe its just me, but looks like thats alot easier than dropping the clutch.
on a side note, i think the earlier model IS350 are slower. the new 07s are some monsters.. i dont know why but the test #s from the mags are putting it right where 335i is from 0-60 and 1/4 in the low 13s.. which is pretty insane.
im hoping the new G37 will put us back in the game
Old Mar 20, 2007 | 12:19 AM
it is hard to believe how a company who spend so much on r&d can under estimate their numbers.
i mean if lexus knew it was able to do 4.9s wouldn't they advertise it?
Old Mar 20, 2007 | 12:24 AM
Klubbheads's Avatar
The hardest part on the car is switching the traction control completely off. Most magazines that go into low 5 territory know how to switch it off. It's an annoying process which most people won't do before starting up the car. Otherwise its a high 13 and low 14 car.
Old Mar 20, 2007 | 12:43 AM
i never knew that
i thought lexus traction controls were permanently on
i mean there is a button to turn it off but it really isn't 100% off
Old Mar 20, 2007 | 12:51 AM
htownboy's Avatar
I make sure VDC is off then let go right under 3K and it launches very well, the clutch grabs hard and the tires chirp just alittle and I'm gone... Yes, you can take the is350, I have done it to my co-workers Lexis more than a few times and have only 2 intake mods, all else is stock on my G.
Old Mar 20, 2007 | 12:56 AM
htownboy's Avatar
"Back in the game" ?
I don't know about that, i've been in the game the whole time and have the same car as you guys... The 'IS' is fast but can be beat by a fairly stock 6MT G with good fuel and a good driver; I can take that IS350 any day on our commute home. (Unless I'm in my truck and then I still can cause' there is a high curb I can drive over and cut behind some stores which saves at least 15 minutes)
Old Mar 20, 2007 | 12:59 AM
Klubbheads's Avatar
Do u run mid 13s in ur car?
If yes then u have a freak. If no then u beat the drivers not the cars.
Old Mar 20, 2007 | 01:08 AM
htownboy's Avatar
Don't know what the car runs, all I know is that IS cannot pull ahead; not from the start and not while cruising down the freeway either... I'm definitely not smoking the IS, but I am in the lead, do you feel me? Someone can figure this out, let me know... All Eric does is mash the gas in the IS, there is not much more he can do, right? Let's just blame it on his reflexes or something now, but then he's 27 and I'm 43 so it should be the other way around. Maybe it's that racetrack gas he burns, huh?
Man I don't know and I can't talk times, just can tell you like it is; the IS can be beat by a nearly stock 6MT G...
Old Mar 20, 2007 | 01:44 AM
LIUser's Avatar
its gunna be toughto beat him unless you get a jump off the line. he's driving AT and just mashes the gas.
i let out the clutch at 3k and dumpo it once the car gets some traction, haul *** through the otehr gears. dont forget to take vdc off
Old Mar 20, 2007 | 01:45 AM
LIUser's Avatar
ps- BE SAFE!!!
