Am I pre-wired for satellite radio?
Old Mar 22, 2007 | 02:26 AM
sfinaki2000's Avatar
I have an '04 Coupe with a SAT button on the dash, no nav. Are all '04's with the SAT button pre-wired for satellite? I'm looking to install the ipod kit from everythingg35.com/g35parts.com but cannot find the harness as pictured in the instructions on the following page:
http://www.g35parts.com/download/ipodinstall.pdf
Any Ideas?
Old Mar 22, 2007 | 07:24 AM
redwillow's Avatar
20 Year Member
yes....that is a sedan, the coupe prewire connection is under the trunk mat on the left side of the trunk by the bose amp.
Old Jun 18, 2010 | 03:37 AM
OSCN's Avatar
Sat receiver in Coupe
Well thanks Red! See OSCN above (6/18/10) Now I know where to look for receiver. My sat is receiving intermittenly, will work sometimes, 2,3,4 . . . minutes then go to no signal. No, I'm not under something, it happens in the wide open spaces.
Old Jun 18, 2010 | 08:07 AM
DailyDrivenCoupe's Avatar
wow so we are pre wired for sattelite radio. i was under the assumption that u had to get the satelitte radio kit that is sold by infiniti. i have a aftermarket sirius but still unsure if it has everything i need. great info redwillow
Old Jun 18, 2010 | 03:39 PM
SpcCain's Avatar
Mine came with a Sirius Radio, but I took it out to install my gauges.
Old Jun 18, 2010 | 06:45 PM
broke_as_ajoke's Avatar
What do I need to use the SAT hook up? Would I have to buy something or just connect it to the bose stock radio?
Old Jun 18, 2010 | 07:42 PM
^ i believe you have to have a module that has to be hooked up. last time i saw tony at riverside infiniti had one. if not west covina nissan might have one. someone correct me if im wrong on first statement
Old Jun 18, 2010 | 10:06 PM
VQ Johnny's Avatar
It depends what you want to use it for, Ipod, satellite radio or both? You can get the Ipod integration kit and with an extra cable can use it for both Ipod and satellite radio. I have the kit in my 04 coupe and just use it for my Itouch, but I also have the second cable if I ever want sat radio, from my understanding you hook both into the the box and just unplug your Ipod to switch to sat radio here is the link for the kit it also gives vin #s to determine if your car is prewired for satellite radio. You have to remove the spare and a plastic cover on the drivers side of the trunk to expose the factory amp and the prewired connector.
http://www.g35parts.com/G35-iPod-Fac...999u7-ipod.htm
Old Jun 18, 2010 | 11:33 PM
gck's Avatar
gck
SAT button, then yes
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
mattdg35
Sep 14, 2015 11:28 AM
