engine stutter
Old Dec 30, 2003 | 02:18 PM
KAHBOOM's Avatar
Re: engine stutter
I've never experienced that... I would let the dealer check it out. That happened on my MX6 and there was something wierd going on with the timing.
2003.5 Coupe 5AT- premiumpackage /performance package/ K&N
Old Dec 30, 2003 | 03:19 PM
JustinP10's Avatar
Re: engine stutter
It could possibly be a slight misfire? Maybe a coil pack or spark plug issue on one of the cylinders or something, free revving wouldn't put load on the motor, so it may just be something that happens under load. Have you possibly gotten a bad tank of gas recently?
Justin McClanahan
Heavily Modified 95 Infiniti G20
www.InfinitiPartsUSA.com
Old Dec 30, 2003 | 05:54 PM
JustinP10's Avatar
Re: thanks for the replies!
Resetting the ECU may not change anything. If a part is bad or something mechanical is causing a misfire, then resetting the ecu wouldn't make a difference. With the car still being under factory warranty I'd probalby look into taking it into a dealer and have them hook up a consult to the car and make sure it's not throwing any codes, yet not turning on the CEL. They can also check out the main sensors (TPS, etc..) and make sure none of them have a glitch or something like that.
Justin McClanahan
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
