my first drift :( :( :(
Old May 19, 2007 | 11:45 AM
  #31
ashadiow's Avatar
Yeah, have one of the guys here buy it for you and ship it as "personal effects" and it will get there fine. Enclose a $0.00 invoice and there will be no importing fee. I think that woul dbe your best bet. It will be like 30-50 in UPS WorldAir Shipping.
Old May 19, 2007 | 12:00 PM
  #32
Neal376's Avatar
you could only imagine my headaches...
your good to go. you can get an aftermarket SPC camber kit.
that is prob why I had so much damage. my SPC camber arm was too strong, and instead of giving way like yours did, my SPC arm pushed my entire subframe to the left.
and this all happened after i spent nearly 20+ hours polishing and performing the 20k maintenance work
the RETARDED body shop I brought it to convinced me that I needed to replace the 1/4 when I really did not...as a result, none of the panels line up and IMO looks worst than the actual pictures above
Old May 19, 2007 | 02:39 PM
  #33
Neal376's Avatar
ok i mean the new work aint that bad. its just that the new 1/4 they installed sticks out further than an OEM panel and as a result the passanger rear wheel looks bit tucked in (even though it alligns perfectly.
lol even the taillights dun match. because the install job was poor, the passanger taillight is angled a few degrees further up towards the sky than the drivers side taillight
Old May 19, 2007 | 05:13 PM
  #34
xx7sephiroth7xx's Avatar
G
that stinks for both the OP and the guy above me ^
GL on fixing it
btw, are those... clear turn signals on your g35, OP?
Old May 20, 2007 | 03:56 PM
  #35
kenempireex's Avatar
Man...that sucks!!!
Anyway, what kind of tail light housing are those? White turning signal is pretty sick!!!
Old May 20, 2007 | 05:09 PM
  #36
1stG35inCTRY's Avatar
Originally Posted by partyman66
You should see if you can get someone that you trust from the board, or a friend in the US to buy it for you and ship it to ya(...)
Originally Posted by smokedhen
at first i couldn't see that what was wrong. then I noticed that the wheel was bent inwards. good luck with getting that fixed. if you trust someone here, you can ask them to send you the part.
...anyone you can suggest ?!??
Old May 20, 2007 | 05:12 PM
  #37
Originally Posted by kenempireex
Man...that sucks!!!
those were custom made by a local guy ...
--> https://g35driver.com/forums/interior-exterior/119819-i-think-i-have-unique-taillights.html
....and he did a hell of a good job with those tails
Old May 20, 2007 | 08:48 PM
  #38
NY350GT's Avatar
1stG35inCTRY,
Я-бы на твоем месте поинтересовался если можно заменить погнутую хрень на аналогичную деталь он Ниссана Z и заплатил за нее из своего кармана. Z в отличии от Gшки в Европе продают, так-что тебе по крайней мере не придется заказывать деталь из США.
Удачи.
Old May 20, 2007 | 09:03 PM
  #39
Scold's Avatar
Originally Posted by NY350GT
1stG35inCTRY,
Удачи.
word.
Old May 21, 2007 | 02:44 AM
  #40
DriftDreamzSS's Avatar
www.battleversion.com
get some stronger **** man. If you plan on drifting much more order some good suspension and a clutch type diff too. Drifting= breaking lots of stuff. Better start stocking up on spare body panels, tie rods and multi link arms.........
Old May 21, 2007 | 02:52 AM
  #41
BayAreaRefuGz's Avatar
i fly low
that's crazy...i've always dreamed about autoX, but now.. i'm having 2nd thoughts. sorry to see that happened. good luck on the repair.
Old May 21, 2007 | 10:03 AM
  #42
b00stedjustin's Avatar
This won't happen in autoX!!! AutoX is all about getting the best time and learning car control. These guys were being dumb thinking they were Takumi, and attempte to "drift" lol
Old May 21, 2007 | 07:26 PM
  #43
adrenaline rush's Avatar
Definitely shouldn't happen during any sort of autox event. Sliding into the curbs on a racetrack I can see doing some damage though...
Old May 22, 2007 | 10:12 AM
  #44
I think you bent the radius arm as well, #9
after some consideration (45 sec ) i ordered it too,,, my logic tells me that it might be damaged even though it looked ok... but it only looked thanks anyways
P.S. will let you guys know how things turn out, it is now at the body shop... I hit some tires on the inside of the curb too yeah I know I am a rookie at the drift but it is how you build your experience
Old May 22, 2007 | 05:04 PM
  #45
redlude97's Avatar
did you order new eccentric bolts also? I would replace those as well on both the camber arm and the spring bucket
