Center Console on my 6mt
Old Jan 8, 2004 | 06:45 PM
bkchang79's Avatar
I have the 04 style center console and it's making clicking noises everytime I put pressure on the pad (which is everytime since I use it to rest my elbow to shift). Can this be fixed under warranty?
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Old Jan 8, 2004 | 07:00 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Re: Center Console on my 6mt
I don't have clicking noises but I do have these creaking and squeaking noises when it's cold outside. The noise goes away after a 15 minute drive with the heat set to 90.
2004 G35C 6MT DG/Gr/Prem/NAV/A.Pedals/C.Corners/C.Bra/PIAA/Grnd.Kit [img]/w3timages/icons/cool.gif[/img]
Old Jan 8, 2004 | 07:36 PM
ReDRoK8's Avatar
For any interior creaks, noises, etc. You can take the car in and have infiniti check and replace parts as needed under warranty. Be aware that they will try to say every time that they could not duplicate the noise so it's best if you show them yourself. Also I don't know what mileage you have on your car but also be aware that in the fine print of the warranty Infiniti specifies that they only cover interior noises for the first 12,000 miles which is totally gay. I had to call Infiniti Consumer Services to get my local dealer to cover my issues when I brought mine in at 15,000. Good luck.
-Jason
Laser Red '03 6MT
Old Jan 8, 2004 | 11:25 PM
GregDallas's Avatar
Just had mine fixed >>
I had a squeak/creak in the passenger side dashboard area. They figured out it was something rubbing with the glovebox and reinforced it somehow. Drove home with no creaking at all. (car is one month old).
04 Twilight Blue / Willow AT coupe 18" wheels and spoiler
1993 300ZX Stage XIII TT 477 rwhp
Old Jan 8, 2004 | 11:59 PM
afr0puff's Avatar
Supa Dupa Moderator
I have this problem too. I beleive its caused by the metal and magnet strip rubbing against each other. I just put pressure on that area and move the arm rest a little to cause some friction. Goes away.
http://www.anythingbox.net
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
RWDguy4238
Sep 30, 2015 12:13 AM
