Drives side window not going up, no warranty
Old Jun 11, 2007 | 08:37 AM
Gidyup's Avatar
After I spent 4 hours Zainoing and cleaning the exterior/interior of my 2003 Coupe, the drives side power window decided to crap out. I had the motor replaced 2 years ago by the dealer and I understand that this is a common problem. After reading some forums I tried banging on the door which worked and managed to get the window up but once in a while it craps out again.
Can someone tell me what the exact problem is, if it's the motor or the solenoid/relay and is this fixable by taking the motor apart and repairing it?
Also, does anyone have the procedure to replace the motor?
$500 is a little steep to have the dealer fix it and I'm sure Infiniti will not extend the warranty for this.
Thanks
Steve
Old Jun 11, 2007 | 09:35 AM
jberry's Avatar
right now my driver side motor is dead, it works when I slam the door hard and hold the power window switch I am trying to get a used motor and put it on myself. There was a link here that showed how to put the motor in, and when you do you have to reset the motor by pressing a button, kinda hard to explain.
Old Jun 11, 2007 | 10:27 AM
imalazeeass's Avatar
500 is a ripoff, the motor is about 175 and labor is about 130 ish. You can always just buy the motor and install it yourself.
Old Jun 11, 2007 | 01:25 PM
AminG's Avatar
yeah, no need for a dealer to install it, just find a garage that works on infiniti's. you might even look around for a pick n' pull to see if you cant find a motor there
Old Jun 11, 2007 | 11:11 PM
Meth68's Avatar
This was a huge headache for me as well. I was still under warranty but I am not on motor #3 which was replaced 2 weeks ago and now when I have my window up and driving I can hear wind coming in through the driver sidewindow. My 2nd motor was so screwed up I could slam my door and my windows would roll down as my car was shut off. Good luck.
Old Jun 12, 2007 | 03:45 AM
eugz's Avatar
http://www.my350z.com/forum/showthread.php?t=225333
CHeck this thread out for help. Its a pretty easy install for the Z. Maybe you can use it as reference for your G.
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
