acceleration noise
Old Jun 20, 2007 | 08:12 PM
JTG35's Avatar
G is a noisy car, i hear all kind of sh*t all the time but my car is still drive like a m*****f****r. You should take it to the dealer and check or roll up your window
Old Jun 21, 2007 | 06:42 AM
TurboDreamzG's Avatar
Originally Posted by ISMSOLUTIONS
OK - if it is happens whenever you hit that speed level, regardless of throttle, you have a loose heat shield to a bad exhaust hanger, or something else slightly loose.
Have you recently had the car serviced, like an oil change? Many of the hoists/posts can rub a heat shield and bend it slightly, allowing it to rub.
Also, it could be the plastic underlining the engine, if a screw is loose, etc., that load point would cause it to vibrate.
Rick
Sounds like a good enough reason to change my exhaust system out eh? haha.
Old Jun 21, 2007 | 11:07 AM
ISMSOLUTIONS's Avatar
....if your looking for a reason...
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
