SLIP light and VDC OFF light are on....
Old Jun 15, 2007 | 05:41 PM
mitsuman's Avatar
What do these mean? Thanks
I think the vdc is traction control? But what is slip? and why would the car turn vdc off automaticly?
It happened the other day when i was on it, just going straight no curves. Havent driven the car in a few days, took her out for a lite spin today and the lights were off.
i do have 2 different sets of tires. Rear are at 90% front at about 70-80%. Thanks
Old Jun 15, 2007 | 05:49 PM
crashnburn's Avatar
see what ur tranny fluid level is.... i had this happen and my tranny was leaking fluid.... made my at check light come on as well
Old Jun 15, 2007 | 05:50 PM
crashnburn's Avatar
i have an auto and drive mostly in manual mode
Old Jun 15, 2007 | 06:27 PM
jsp872's Avatar
^does it shift for you if you dont shift?
Old Jun 15, 2007 | 06:47 PM
AthensBlueG's Avatar
Brian
Your brake fluid might be low, which can cause this reading. It happened to me when it was time to replace my front brake pads. Within a few days to a week of daily driving, the lights went away on their own. Then the lights came back within 2 weeks. Got my front rotors resurfaced, new front pads installed, and the problem went away.
How many miles on your coupe and have you had your brakes replaced yet?
Old Jun 15, 2007 | 09:11 PM
dr.g35's Avatar
like athnesblueg said check your brake fluid, i took mine to the dealer to have it serviced and on the way home they came on. When i got home check the fluid level and it was below the min mark.
Old Jun 19, 2007 | 08:13 PM
mitsuman's Avatar
I noticed also that it only does this when i am flooring it. If i start the car and drive normally all lights will stay off. Also another thing that comes on is the brake light. but the brake is off.
I havent had a chance to check the fluid. Will check tonight when i get home. I just bought the car so im not sure about the brakes. The fronts need to be turned though, i can feel it. Thanks guys for your help.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
03sedang35
Aug 29, 2015 07:56 PM
