crazy turn signals
Old Jan 13, 2004 | 05:52 PM
guidoucla's Avatar
crazy turn signals
My 2003 sedan's turn indicators have gone crazy. They flash okay in the front but in back both sides flash very dimly. When you step on the brake with the turn signal on, it acts like the emergency flashers and if you use the turn signal it cuts off the cruise control like you stepped on the brake. The dealer has had the car for four days and can't find the problem. They've already replaced the main computer. Has anyone else experienced this? Thanks
Old Jan 14, 2004 | 03:37 AM
SkidMark's Avatar
Re: crazy turn signals
I've never heard of anything like that. Your car is possessed
HIS: 2004 G35 Cpe 5AT, Desert Platinum, Perf & Prem Package, K&N Air filter, Alba Wheels, ClearBra
HERS: 2004 G35 Sedan 5AT, Ivory Pearl, Perf & Prem Package, Rage Wheels, K&N Air filter, Sat radio
Old Jan 14, 2004 | 09:06 AM
Micah's Avatar
Usually when turn signals behave differently it's because either there is a blown-out bulb or the signal relay is bad. But these should have been the first things the dealer checked.
Old Jan 14, 2004 | 10:25 AM
dragon_long's Avatar
If you recently changed a bulb, change it back.
Old Jan 14, 2004 | 11:50 AM
guidoucla's Avatar
After five days the dealer found a bad turn signal/headlight combination switch. Everything is fine now. They fixed it under warranty.
Old Jan 14, 2004 | 12:23 PM
tpware's Avatar
yeah, thats the first thing they should have checked, the relay, then the combo switch.. I had something similar in my old 2k maxima. It was the relay in that case.
bs g35c lth/prem
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
