Non Synthetic for first 10k Miles??
Old Jan 14, 2004 | 11:54 AM
GG35's Avatar
is it true that it is better to use non synthetic for the first 10k miles or an i go ahead and use full synthetic oil?
Old Jan 14, 2004 | 12:07 PM
JustinP10's Avatar
Re: Non Synthetic for first 10k Miles??
You probably wouldn't have to run normal dino oil that long. Everyone's going to have a different opinion on it, I may run normal oil for the first change or two, but I would guess that synthetic would be fine before 10K. Your motor should be fully broken in well before that time.
Justin McClanahan
Heavily Modified 95 Infiniti G20
Working on a G35 Project Coupe
http://www.infinitipa.zoovy.com -> www.EverythingG35.com
Old Jan 14, 2004 | 12:14 PM
GG35's Avatar
whats dino oil?
Old Jan 14, 2004 | 12:26 PM
tpware's Avatar
While its true that the VQ continues to break in up to 10K, most VQs seem to have settled into their characteristics by 5K. You're making about as much HP as you will at 5K. Personally for me, 5K was a nice compromise between the breakin and the added protection of syn*.
* I use syn because I like its cold pour flow for startup and resistance to sludge.
bs g35c lth/prem
Old Jan 14, 2004 | 12:39 PM
JustinP10's Avatar
Non synthetic oil. If you wait until 10K to change over to synthetic it won't hurt anything, but at the same time, if you're coming up on a change at like 8K or something like that, it may not hurt to swap then too. A great way to find out how often your oil really needs to be changed is by sending a sample to blackstone labs for testing.
Also, Nissan oil filters are probably the best I've found. Mobil one's good too, but a lot more expensive. The generic filter's suck, many don't have anti-drainback valves, etc...
Justin McClanahan
Old Jan 14, 2004 | 05:56 PM
tpware's Avatar
"Also, Nissan oil filters are probably the best I've found"
I suspect you are thinking of the old ones, the newer filters for the VQ35 have cardboard end caps.. Shame, the old filters were definately high quality.. made things easy..
bs g35c lth/prem
Th611
Oct 27, 2015 03:48 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
derres
Aug 28, 2015 03:27 PM
RA081024
Aug 18, 2015 07:03 AM
EPG35
Aug 16, 2015 04:52 PM
