Better handling...where to start?
Old Jun 21, 2007 | 08:07 PM
thejared's Avatar
i want my car to stick to the damn road when i take a turn at 40.
what do i need suspension-wise?
whats the best, and where can i buy them.
strut bar?
sways?
springs?
struts?
shocks?
i know absolutely nothing about suspension stuff, except that its cheaper than adding power and warranty-friendly usually.
yeah and i also want to keep the stock 19's/ thanks.
Old Jun 21, 2007 | 09:21 PM
redlude97's Avatar
springs and sways is where I would start, and depending on the drop, shocks as well or a good set of coilovers
Old Jun 21, 2007 | 10:27 PM
GTT's Avatar
GTT
G35 Twin Turbo
^ that's a good start
Old Jun 21, 2007 | 11:36 PM
ttrank's Avatar
Grocery getter
Springs and sways will be big!
Old Jun 21, 2007 | 11:59 PM
izmir41500's Avatar
G35driver Addict
i agree. springs + dampers or coilovers, sways, strut bar, then everything else.
Old Jun 22, 2007 | 12:04 AM
jsp872's Avatar
agreeeed!!
Old Jun 22, 2007 | 01:03 AM
gary c's Avatar
Quick......around corners!
My vote......Stillen sways......Tein Z H techs........Richie Strut bar. You can
do this in any order you wish but once the sways and strut bar go on you'll
be a "Tight Ride" By adding the H-Techs you're lowering the center of gravity
and body lean won't exist......just like mine!
Old Jun 22, 2007 | 01:11 AM
dofu's Avatar
20 Year Member
Tires... good tires.
Old Jun 22, 2007 | 01:41 AM
PhxBlue's Avatar
Polyester Pileup FTW!
What year is your car? Im gonna guess a late 04 or an 05 judging by your sign up date. Here are some links of good items to use. Basically its all the stuff mentioned above. You dont have to buy from the sites listed, they were chosen randomly.
Sways
Springs
Strut bar or Strut bar
These wouldnt hurt either
Old Jun 22, 2007 | 03:36 AM
tinman143's Avatar
sways
Old Jun 22, 2007 | 04:28 AM
Mad Paradox's Avatar
J-Dizzle
Spring and sways, I recently installed Cusco sways and Tein coilovers, BIG difference in handling. Later on, you can get the struts, lower tie bars, lower the car, GTSpec 4 point mid chassis brace. =D
Old Jun 22, 2007 | 09:49 AM
bassholic's Avatar
So you guys are saying getting springs instead of coilovers is fine
Old Jun 22, 2007 | 10:58 AM
watsgoodG's Avatar
Do the stillen sway bars squeak...and what stiffness would you recommend. Is it a diy or have it done...one other questions does it effect the ride...thanks
Old Jun 22, 2007 | 11:08 AM
GT-Ron's Avatar
I simply didn't want to drop my G, as I've encountered too many issues on past cars that I didn't want to deal with this time around.
That being the case, I added sway bars to my '05 6MT and it made a noticeable difference. Very happy with the results.
If you're not already set on spending big for coil-overs, and you're not sure if you want to decrease your ground clearance further, then sway bars would be a great place to start. See how you like the improvement and then consider additional options, if you still want to.
EricIsKlumzyee's Avatar
tires..
